Rounding Third For Home!
All of the modifications discussed have been completely installed into Channel B, such that the wiring for that channel is now complete. For review, those modifications include:
A. Removal of the bleed circuit between the Tape Monitor and Aux 1 inputs.
B. Removal of the active Phase Reversal switch circuitry.
C. Removal of the Center Channel Record Output jack circuitry.
D. Removal of the Reverb Input/Output jack circuitry.
E. Removal of the Remote Volume Control connector circuitry.
F. Removal of the powered center channel output circuitry.
G. Removal of the Low Filter switch circuitry.
H. Removal of the High Filter switch circuitry.
I. Removal of the old three stage line amplifier design.
J. Relocation the Tape Monitor Input switch to immediately after the Mode Switch to equalize the gain of this input with that of the other high level inputs, and to eliminate the phase reversal that existed between the Tape Monitor Input and the other high level inputs.
K. Relocation the Record Output jack signal to be sourced directly from the Mode Switch. This eliminates the phase reversal that existed between the source and record output signals.
L. Providing a low output impedance unity gain buffer to isolate the Record Output jacks from the internal signal path in the amplifier.
M. Install a new two stage design 12AU7 based line stage amplifier, eliminating the need for 7247 tubes, as used in the original design.
N. Convert the old High Filter switch into a Tone Control "ON" switch, to allow the tone controls to be included in the signal path when desired.
O. Convert the old Reverb In/Out jacks into Preamp Output/Power Amp Input jacks.
P. Provide a low output impedance unity gain buffer to drive the new Preamp Output jacks.
Q. Convert the power amplifier section to have the Common output terminals operate at ground level.
R. Correct HF stability circuits in the power amp section to optimize HF response while maintaining excellent stability and distortion characteristics.
S. Install new output stage B+ plate supply filter to eliminate significant 120 Hz hum in output.
T. Provide new low noise ground point for all grounds in the tone control amplifier circuitry to eliminate notable hum in the output.
U. Correct as received issues with broken rear panel leads, exploded output tube cathode resistor, bias supply, tone control stage B+ supply, coupling circuits into the left channel output stage, installation of screen stability resistors, AC wiring, and installation of appropriate current inrush device.
With the conclusion of this litany of changes, I have now been able to get some serious listening time in with the stock Channel A, and the modified Channel B -- both with the tone controls in, and out of the signal path. I list all these changes not to impress, but to give a full understanding of the scope of changes being made. This was also the first time (other than when I first made the necessary repairs) I have been able to listen to the unit with it fully buttoned up after Channel B has been finished.
In this latest listening test, a number of observations were obvious from the get-go, and include:
1. On 101 db efficient speakers, the unit is nearly dead quiet now, requiring your ear to be firmly against the speaker board to hear anything. The horns only emit a very quiet hiss, indicating that amplification is taking place.
2. Advancing the volume to full with no input to the Aux jacks produces a notable increase in hiss from Channel A, while the same conditions produce only a very slight increase in hiss in Channel B. The difference in noise between the two channels is quite significant, particularly considering the power output capability at play here.
3. Placing a dead short on the Record Output jack of channel A kills all sound in that channel. A dead short on the Record Output jack of channel B causes no change in the sonic character of that channel at all.
4. Throughout all of the significant development work, the output tubes have held their bias settings very solidly. With the addition of the screen stability resistors, they seem very stable in operation, and quite happy in their task.
In spite of all these changes, this unit still commands its identity as that of a Fisher X-1000. Outwardly, only the LF & HF filter, and phase reverse switches no longer function (HF filter switch is now the TC ON switch), while the wiring to the unused SpaceXpander control has been removed. On the back panel, the Remote Volume and SpaceXpander connection jacks have been disabled, as have been the powered center channel output and Center Channel Record output jack. All other functions and features of the unit remain in place, and now include the new Pre Out/Power In jacks as well. The active controls all still work very quietly and smoothly in operation as before. Input sensitivity and impedance are also identical to the original specifications.
Sonically, the new channel is very similar in many ways to the old channel, but includes some important differences: The bass is notably deeper in the modified channel, and the highs are smoother, but with more detail. Overall, the presentation is more balanced. On lower quality recordings, the changes are hardly noticeable, while on high quality recordings, the difference is striking. Considering the improved sonic presentation, complete absence of noise, and worthwhile feature changes, I think the re-engineered unit is a much more capable device, while still retaining the best of its original purpose and features.
With this then, all that remains is to document the performance between the two channels, and then start the installation of these modifications into Channel A. Since much of the groundwork to accomplish that has already been performed with the work of installing the modifications into Channel B, it will go much, much quicker from this point, although the original Channel A line stage design must obviously first be removed before installation can begin. Still, this project is rounding third for home.
For now, pics include:
1. This 12AX7 tube will ultimately perform as the Recording Output Jack Buffer stages for both channels. For now, it is serving that function with the wiring on the right side for Channel B, while the original wiring on the left side is the input stage of the Channel A three stage line amplifier in the original design.
2. This tube is still the second and third stage of the original line stage for Channel A, while the two switches behind it are the Tape Monitor and (new) Tone Control On switches. The right side of each switch represents new Channel B wiring, while the left side of these switches still performs their original functions as designed.
3. A close up of the tone control amplifier. I ran out of available t-strip terminals, so I secured an isolated strip on the back of the Stereo Dimension Control with adhesive to allow for secure connections to be made. These connections represent the output of the tone control amplifier stage. The single black wire over the Dimension Control maintains the original Channel A connection, while the strip ultimately allows for the shielded cable connections to be made, that route this signal over to the TC On switch in the new design.
4. A complete view of the bottom side as it currently exists with Channel B completely finished, and Channel A awaiting installation of its modifications.
5. Running quite happily after about 10 hours into the first listening session.
With the end in sight, Don will soon be able to add his critical analysis as to his performance perceptions as well, which I certainly welcome. He will need to get a couple of good 12AU7s ready, as it won't be long now!
Dave
