Fisher x100-3 power transformer
CORYK
What should the a/c voltage measurement be on the secondary outputs of the power tranformer on an fisher x100-3 with 105-117 v primary input? This would be on the rectifier winding side. Thank you for any assistance.
If you're having trouble powering the filaments to the tubes, there are a couple of resistors in there that you can change the values on to boost the voltage, particularly to the preamp tubes. I can't recall the positions without the unit in front of me, but if you have a schematic, one of them is right near the filament listings on the schematic. If you remove it, the only consequence is that you lose the ability to keep a load on the circuit if you pull a preamp tube while the unit's running. You'd pop the fuse. That's how mine's set up now.
Did I understand your question correctly?
I wonder because I answered what I see as the primary problem with these, and it may not be what you're asking. I guess I inferred.
Don, The filiment supply seems fine 6.7 volts. Its the other secondary winding I was inquiring about.
