i can well believe it being as this manual has so many errors .I thought it was confirmed my many on here (Sansui forum) that it is actually the opposite?
Trust me I know these amplifiers well, clockwise decreases bias on G8000/9000.I thought it was confirmed my many on here (Sansui forum) that it is actually the opposite?
Yes you need a MY4-02-DC24 which is the solder pin version, you've got a plug in version there.The replacement Omron MY4-DC24 Mouser part # 653-MY4-DC24 is the wrong part.
The tabs are too big, they need to be very small to fit.
Is there a relay that will fit this location?
What soldering iron do you have?Desoldering gun has little to no effect. The pins and factory solder are very large per pin. Even with extra flux applied, nothing. What's the trick to these?
This is the one you want.The replacement Omron MY4-DC24 Mouser part # 653-MY4-DC24 is the wrong part.
My trusty 40W Weller TCP iron makes short work of anything like that - especially if I switch to a 5mm 'number 9' bit (the hottest) - I normally use a chamfered 3.2mm conical number 7 bit.it's just the factory ones refuse to vacate the property
