thesaint
Ok,
I wanted to get some clarification of how to proceed forward from where I am at currently.
All output trans have been replaced, both F-2806 boards have been rebuilt with all suggested replacements.
All relays have been replaced.
Regarding the Bourns bias pot, if full clockwise is down and full counterclockwise is up, where do you want me to set it to safely start with?
I have reinstalled all boards and connectors, thank God for pictures and notes.
Now rewinding back to the original issue before all this work was done, this 8k turned on correctly, did not have any protection issues, but had no output and low distorted output in the other channel.
The preamp connected to another amp does work correctly.
Can I now try to fire this up on the dim bulb? If so, should I try to dial in the bias while on DB?
Thank you for your answers!
