ryanward84
Well-Known Member
I'm looking for a good cart to match with my Denon DP 1200 arm which has an effective mass around 15g.
Price under $150.
Price under $150.
Price under $150.
Slightly below budget:
Audio Technica AT 95VL
http://www.lpgear.com/product/LPGAT95VL.html
Shure M 97xE
https://www.amazon.com/Shure-M97xE-...eywords=shure+m97xe&psc=1&smid=A1FEN8WPYFT9YE
A bit above budget:
Audio Technica AT 440 MLb
https://www.amazon.com/Audio-Techni...UTF8&qid=1477499061&sr=8-1&keywords=at+440mlb![]()
Hi,
The MP110 is not a good match. Nagoaka's published compliance
specs have been for decades much lower than the reality. The real
values are quite high and make a mockery of their cartridge mass.
(Though they explain the typically excellent tracking ability.)
+1 for the AT95VL. Ideal. Tip will last much longer, > 3 times
than any other budget elliptical and sound better than nearly
all of them (well set up) with its VL 0,2 minor radius. Its the
big major radius, 3.0, compared to an ellipticals 0.7 rhat
gives the extra stylus life, and reduces any record wear.
It also tracks a different groove to typical sphericals
and ellipticals, making the best of older worn records.
rgds, sreten.
Not really a very helpful reply I realize, but when I had my DP-1200 I ran a couple of MC carts on it and the table was definitely good enough to justify them. I also ran a vintage Empire 7000z and that also worked out nicely.
Would something like this VL stylus replacement http://www.lpgear.com/product/SHN091VL.html
and a Shure M91ED make a good match and provide similar benefits as the AT95VL?
Hi,
I'd expect the the Shure combination to work better in much lower mass arms than the AT95VL.
I can't say much about the sound, I don't know the Shure, but it seems fairly high compliance.
Too high IMO for an effective mass of around 20g (arm effective mass + catridge weight).
rgds, sreten.
Well, after having used my Ortofon OM10 for about 18 months, I think it's time I either replace/upgrade the stylus or go with a new cartridge. I enjoy my system and so I am in search of a cart that will play well with the previously mentioned Denon DP 1200 and also my Yamaha CR 1020 and ADS L810 speakers.
The amp is very neutral and clear an the speakers provide a lot of bass and good balanced mids and highs so they match up well to my ears. The OM10 sounds better than the AT95E I used before, more balanced and less shrill top end, but I am interested in trying something new. I get the feeling that if I get a cart that is too "warm" or bassy that my system will sound muddy... but I also don't want my system to sound shrill or with strident treble.
Here are my considerations within my around $100 budget:
OM20 stylus or LP gear equivalent
Nagaoka MP110
Grado Blue or Red
Vessel A3SE
New AT VM95EN nude stylus and AT95 body
AT95VL
AT VM520EB
Any other suggestions or experience with these cars and their sound?
The only cartridge under $100.00 is the Vessel A3SE with the "Super elliptical" stylus.
Super and ultra elliptical usually means HE, hyper elliptical a good thing!![]()
Is the mass of the Denon's arm to light for the Nag-110? It's mass is not given in the manual. It does say cartridges between 5-11g can be used. Just a little confused by your answer. I re read the op and saw the 15g mass.Hi,
rgds, sreten.
By the way too the OP I think the LP-gear Vessel is another one you should look at.
https://www.lpgear.com/product/THEVESSELA3SE.html
Kool!!! I like Grados, I just bought a Black-2 to try out. The Grados I have used so far really like my AQ-P-T9 with fluid damping. I am thinking of trying the Longhorn mod on the Black and trying it on a Rega arm.Yes, Vessel A3SE and Nagaoka MP110 are both carts I considered. I just found a Grado with a a few hours on it for cheap and decided to give it a try.
