It is best if you measure the output trans out of circuit to be sure. Measuring something in circuit especially if it is attached to a cap will give you weird results.Thanks, all, that is useful help! I do have a couple of other questions. 1) I am thinking of using a pair of 20 ufd 900vdc film caps for the power supply instead of two 'lytics in series, that should be better than fine! 2) was measuring the taps of the output tranny, one side across the tube sockets is fine, but from the center tap to the tube sockets is .515 meg, so probably measuring something else. From that I conclude that the center tap to one side of the output tranny is gone whereas the winding from the plate to screen is OK, so it looks as though that W5M has a blown output tranny, correct?
@Tubologic
Pardon my ignorance but could you better define or provide an example of hot-switching?
Would 'hot switching' be illustrated as an occurrence where a commercial power outage has taken place and then a quick flicker of commercial power is resumed? Like a quick on then off, then on again?
Apologies for the poor examples on my part.
Yes, that would be one possible definition. ON-OFF-ON in a very short sequence, which leaves too little time for the ICL to cool down and regain his high value "cold" resistance.
The CL-90 ICL has about the same "cold" resistance (120 ohms @ 25°C vs 100 ohms for the Surgistor used by Heathkit) but very likely a much shorter "ON" switching delay time and (unlike the Surgistor) is "non-resettable" when hot switching, thus it offers less protection, but still better than nothing.
Reduce the inrush current and the spot heating issue goes away. Heathkit's modification resolved the issue, and joy returned to Mudville.
Are the CL-90 and CL-120 (either/or) adequate for this application?
I am dubious that the few seconds delay from these thermistors is adequate to properly ameliorate this particular problem. Given the well-known issues with inrush current for this particular amplifier line, it would be best to err on the side of safety.
The surgistor delayed application of full current for approximately ten seconds. That greatly reduces the heating which, we must remember, varies as I^2 x R. So halving I will greatly reduce the heating by a factor of four.
A simple delay can be constructed using a 555, a transistor, and a relay. The current flows through a resistor, limiting the value, until the 555 fires closing the relay.
