Help identify Acoustic Research Speakers
kidadam
Hey, wondering if someone can help me identify these speakers.
I thought they could be AR4-xa but the wood trim around the grill is different. Any ideas?
The driver configuration and back plate/terminals/attenuation switch all look correct for 4xa, but I've never seen that cabinet. I'm sure some of the real AR experts will weigh in soon.
AR-6 1970 - 1976
8" Woofer
1.25" Cone Tweeter
48-20k ± 2.5db
86 db
Crossover Frequency 1800hz
20-100 w
8 ohms
12x19.5x7
20.0 lbs
Retail $72-81.00
AR6 seems to be a close match. I think they sound great, the stage is really impressive. I may pick up a Scott 222d to run them.
Seems like we have a winner! I have an older set of AR6's, with Zobel on the woofer. I think they are exceptionally good for their size and era. Low frequency performance is astounding for such a small box.
Thanks, everyone!
I was originally selling for a relative but after demoing I decided to build another stereo for the attic or maybe cottage.
I have those too. They also have a different woofer than the later run which used the 'standard' 8" woofer. The older models with the inductor on the woofer circuit have a woofer where the magnets surround the voice coil for a longer throw. Those go as deep in the bass as the AR 10" woofer. The AR 6 in the first pics may be a European model. The cabinets were a bit different. The oldest AR 6's have variable pots. The newer ones with the standard woofer have toggle switches.
