Help on a fastener.
Jerry Hawtho
Any idea where to source a driver to remove this fastener? A Phillips won't work. It is used on a Chinese scope and the head is 5mm.
Butter knife, obviously.
If it doesn't gain purchase in the screw slots, then slip in under the flange and bend up at 3 and 6 o'clock and then grab wirth pliers.
If that fails, Amazon has really cheap 'stripped screw' tool sets.
Try a Japanese JIS bit just diffrent enough from philips head .
Compatibility: A JIS driver works well on both JIS and Phillips screws.
A Phillips driver will damage a JIS screw because it cannot seat all the way down into the recess
Lonny
Of course, that picture has too square looks in the middle compared to the real thing...;)
