Help on Speaker repair
jim1889
I have some technics SB-A52 grandson poked the dome on one of the bass and I need to know how to oull the dent out it is not ripped or have a hole just dented in
It appears it's plastic of some type. I'd rather not poke it with a needle like I've people do. Try a strip of the boxing clear tape. Have it line the whole dip and pull from the in to outside.
actually I found a youtube video and it show tape used I try it and it work very wel you can hardly tell it was dented in thanks for the reply
You can also dampen the dent area and after it soaks in THEN take a vacuum and pull it!
DC
DC
they are a poly propolyne or type of plastic if they were cloth or paper I actually used packing tape and they came right out very surprised
Use a vacuum with a small nozzle attachment. Preferably smaller than the dome itself. Wet it and get a good seal then pull out if necessary. They should pop right out unless they crunched it in good all the way around. If that's the case, try some scotch tape.
