Hitachi SR-304 Dial Lamps
Manitoulin
A proud member of AK
Good day.
Anyone have the schematic, or specs or the dial lamps for a Hitachi SR-304 dial lamps?
Not your normal bulb; they are fuse sized, but have pigtals.
Thanks,
Joe
Maybe 12v/250ma meter lamps? :scratch2:
PS - CAREFULLY get an AC voltage reading to be sure!!
Thanks for the advice.
Problem is no-load AC voltage readings when all dial lamps are out can be OTL, to say the least. Also, because this unit has a green plastic "cover", the correct current rating will be important, so I do not melt the plastic.
I usually only have no-load problems with FM stereo indicators, Dave.
Measured 6 VAC at the input to the board, so, most likely there are 6V bulbs. Now, where can I find fuse sized bulbs with wire leads????
I'd go with 6.3v/100ma or 6.3v/250ma, a working lamp would need an amperage reading in series with it to determine what the actual existing ones are, both ratings are readily available, 250ma is probably a better choice when going through tints, Dave. :yes:
[/IMG]
