Additional testing now indicates good performance from these little amplifiers. Initial distortion measurements were somewhat disappointing, but increasing the cathode current to about 50mA resolved that issue. I'm using the 1222A tube, which is electrically equivalent to an uprated 6L6GB with a 21W anode rating.
Maximum output power really took a hit compared to the earlier tests in the A500 chassis, due to the reduction in screen voltage. It's about 21W at 0.45% THD, which is almost identical to the factory continuous power specification (20W at less than 0.5% distortion). The screens are now at +310V, rather than being powered directly from the +400V B+ line. I was concerned about tube life at the higher voltage, so it's a reasonable trade off. Screen dissipation at maximum output measures about 2.1W, which is within the 2.5W rating for a 6L6GB.
The use of a different driver topology and 20dB of feedback appears to have improved on the manufacturer's distortion numbers. Where HK quotes "5 watts at less than 0.2% distortion," these measure 0.057% THD at that output level. 1W distortion measures 0.032%.
Here are a couple pics of the inside of one amp on the work bench:
This chassis was deep enough to allow physically positioning the heater wiring well above the active circuitry. I like to run it across the chassis space at the top, then drop it down to each socket where it's needed. I almost never twist heater wiring, but I do use tie-wraps to keep it parallel. That works just as well and is much less work. The heaters are also elevated electrically to about +50V. With the input shorted, output hum and noise measure 0.55mV RMS. With the input open, that increases to 0.80mV. These will be quiet amplifiers!
Jack
