You can use the pre out/power in but that will be a noisier way to do it. Line level is a higher level signal than the pre out unless you are using almost all the volume.
There is a replacement tape monitor circuit on the back of the EQ, maybe put the 8-track there. Select 8-track with the Ross tape monitor switch.
Note this unit uses industry standard, ¼" TS phone plugs for the main in and out and uses RCA plugs for the tape monitor loop. If you haven't found the manual there are parts of it in a bay offering now that you can get and learn a bit.
