Kegger
R.I.P. 1/12/1966 - 6/1/2017
Rather long winded reply by myself, sorry guy's!
OK my assestment of the HPM to my ADS L880 is pretty much on par with what all that
attended the shootout had to say. The Large ADS speakers are just a step up the latter
from your standard HPM, JBL-L100 and like, Cerwin vega, advent, many other mid grade
to slightly upper grade speakers. They just do everything better with a much more refined
sound with also having greater definition. They can play any kind of music and do it well.
Very very good to great bass extension, warm mids and detailed highs, describe the ADS.
(In a lively room and on some gear the ADS can have a slight emphasys in the treble region)
In my oppinion the HPM series are not a bad speaker just not in the same league as the ADS.
OK I have both HPM-60's here and the 100's that I have done extensive testing/tweeking/
modding/poking/proding with every combo under the sun I could come up with to find what
would be the best attributes of these speakers and what makes them perform best, plus
try and isolate there weeekness.
In my oppinion there are 2 areas where the HPM has it's weekness and could be improved.
The xover on these woofers is to freakin high (1.5-3k) which causes bad off access frequency
response, not very forging lower midrange performance with a driver to large to produce them
correctly and backwave from the port of the woofer has lower midrange coming from it which
gives you this hollow or echo type sound (not good). And the tweeter is your typical vintage
paper cone tweeter that has neither extension nor definition and a rather skreachy sound to
it comparred to a good silk/soft dome tweeter on most amplifier setups.
A quick tweek to make these better sounding is replace the tweeter with a good silk dome
like say the DAYTON from PE, take the pot out of the signal path for the tweeter, increase/
improve the internal stuffing of the speaker and use a more laid back amplifier. Pretty good!
(if the xover has electrolytics in it also (as some do) then replace those with poly's)
Another larger tweek would be redo the xover and drop the woofer point to around 700-800hz.
There are a few good attributes of these speakers though! The impeadence curve is relatively
flat and high with a very simple xover which does lend it'self nicely suited for tube amps, then
toss in the higher sensitivity and it makes it a choice for low power great sounding tube amps
to be tried on here and in my experience a very worth while combo. Now anyone who knows a
really really good low power tube, ecspecially single ended triodes will tell you they have great
tone and a musically inviting sound to them that can only be appreciated on a speaker that has
simular electrical characteristics as the HPM's. Simple xover's and high sensitvity let the amps
sound come through and when paired with the HPM you get a taste of what a combination like
that can sound like and be very rewarding. Actually sounds pretty darn nice!
(could be improved with above tweaks much more) OH yah they also play loud!
You can't just throw any tube amp at them and get great results. The woofer in the HPM needs
to be harnessed and not just let fly like what a 6bq5/el84,7868,7591,el34 and alike type vintage
amps, but more like a 6L6GC/5881 or a 300B. A 2a3, 45, or some other sub 5watt amp does not
have the gusto or grip of the bass to keep the HPM woofer in line but with 90db-95db speakers a
300B is a great choice and works pretty darn well to give you the magic of the amp, keeping the
imperfection sounds of the speaker to tolerable levels and providing darn nice bass respose to boot
with a greatly improved midrange presence.
(Yes 6bq5/el84,7868,7591,el34 and alike type amps can be used but your typical non modded/rebuilt
versions of these amps tend to be rolled off at both ends and flabby in the bass which adds to the sub
par qualities of the HPM with it's lower extension of the highs and somewhat loose bass so it makes it
worse in most respects of the frequency extremes but can make the mid to lower treble area sound better)
If all you wanted to do was rock out and really really like the forward west coast sound then the HPM in
it's original form may be right up your alley as it has those attributes in spades.
(I would like to hear the HPM-900 as it does have some differences to the others that may make it better)
