Yeeterkeeter
Kermit the Frog
If it goes in trash, it will come out trashIt all starts with the recording
Not if you set it up correctly...If you go full tube-crazy on your setup (ex; tube phono pre, tube preamp, and then a proper amp) you're going to end up with a lot more distortion than you want.
Hm. Fair enuff.Not if you set it up correctly
A stereo/mono amp designed to power speakers versus a preamp. Admittedly I was a bit vagueWhat "proper amp" are you referring to in your analysis?
I don't understand why people say this? You've obviously never heard an all tube system. I have multiple integrated amps from the early 1960's and they sound incredible. With tubes in the entire path.Also, I've come to discover that tubes are best enjoyed in moderation. If you go full tube-crazy on your setup (ex; tube phono pre, tube preamp, and then a proper amp) you're going to end up with a lot more distortion than you want. Its better to tube one part of your setup and leave the rest solid state.
How did you discover this?Also, I've come to discover that tubes are best enjoyed in moderation.
There are way too many variables to make generalizations like thatIf you go full tube-crazy on your setup (ex; tube phono pre, tube preamp, and then a proper amp) you're going to end up with a lot more distortion than you want. Its better to tube one part of your setup and leave the rest solid state.
Passion Audio Kit PAK-L11, from 2000. The cathode followers warming up would put out a big pulse which was harmless with low power tube amps, but not friendly at all with bigger power amps.
Many tube preamps have a mute/delay circuit at turn on (plug it into a manually switched power outage device if no delay) that allow them to be (safely) used with a dc coupled ss amps.
Not really the tube preamp's fault.
11.
What do you mean by control?
Condolences! But congrats too.I just recently became an audiophile a couple months ago, so I'm pretty new to the whole deal. What are the benefits of using a tube amplifier over a solid state or a digital amp?
Interesting point. I'm getting a new CD spinner for the Holidays for my living room rig. That's means my old Ah! Njoe Tjoeb 4000 CD player (tubed output stage) is going to the my media room headphone rig. For a good many years I've been running an OG Schiit Vali (microtube) headphone amp with an old Cambridge Audio CD player (solid state) in my media room headphone rig. So I put the old CA in the closet and hooked up the 4000 to the Vali ..Also, I've come to discover that tubes are best enjoyed in moderation. If you go full tube-crazy on your setup (ex; tube phono pre, tube preamp, and then a proper amp) you're going to end up with a lot more distortion than you want. Its better to tube one part of your setup and leave the rest solid state.
too muddy .. that combo did not work out.
.. now we're cooking with gas. Was not expecting that. Previously I always preferred the sound of OG Vali to OG Magni on my headphone rig CD spinner.Overall impressions are really good so far. Ignore the tubes in the backgroundView attachment 3056234
Look what just arrived! Yippie!
When I say broke, I mean that it makes a really loud buzzing noise when I switch it over to the Phono input. I tried the turntable on the internal amplifier, and there is no noise like that. I also checked, and the tubes seem fine as well. Oh well, I guess I ought to find another phono amp that uses 5670 tubes.Well, I got some bad news... The doukmall amp broke. This is unfortunate
have you wiggled the RCA or ground connections to see if the problem goes away?When I say broke, I mean that it makes a really loud buzzing noise when I switch it over to the Phono input. I tried the turntable on the internal amplifier, and there is no noise like that. I also checked, and the tubes seem fine as well. Oh well, I guess I ought to find another phono amp that uses 5670 tubes.
