bolero
Something is going on... Cornwalls are known to have very good bass response and if they don't something is wired out of phase or the components are not correct.
Ya think?? Have you read the rest of the thread? Hahaha...
What does it cost to recone these?I guess I'll be getting these woofers reconed to original specs: are there any particular recone kits I should be using?
( I read that 8ohm vs 4ohm on these = 3dB volume difference in the low end, which is significant. Also apparently it messes with the crossover network ).
And thanks again, to everyone for the help. These Cornwall 2's will be returned to their former glory.
Here are the T/S parameters of your woofer.
It’s a 4 ohm vc.
Did you take a meter reading of the other woofer to see it’s resistance?
This is a prime excuse to buy the GRS K33 from Parts Express and some foam window tape from your hardware store.K33e and k34e are functionally identical. Just mounting gasket differences.
https://community.klipsch.com/index.php?/topic/115473-is-k-33-and-k-34-the-same-woofer/
If anyone has a K33 or K34 laying around, I'd be curious what DC resistance you get across the speaker tabs?"
So it looks like the cost to recone these K33's is approx the same as to buy new speakers.
What are some recommended replacements?
So far I've seen mention of:
Crites stamped frame
GRS at Parts Express
My originals were made by Eminence, I believe. Mfr code 67.
According to my research, The later K33's used in the CW2 had a higher Fs/ resonance frequency than the earlier ones
Should I be overly concerned about this?
And thanks again, for any advice!
