Well, its really a developmental platform as I see it. I tried to do all the basic things right and since the cabinets were being built from scratch, there was tons of latitude within the displacement I could determine from the original RSb design which I expanded to offset the larger bracing, dampening and mid enclosures>
All materials need to be
inexpensive and readily available locally. Everything came from Homedepot, Hobby Lobby, Lowes or Ace Hardware. Most were scraps or remnants. I studied religiously the BBC British designs, LS3, BC1, etc.. The available data on capacitors and reviews was mind numbing with terms like "fruit forward" and what knot. These were references:
http://www.humblehomemadehifi.com/Cap.html and
http://zerocapcable.com/?page_id=224 The drivers and parts were purchased off Ebay for less than $100.00 including shipping. And finally, there is probably more than 2.5 months of almost everyday work in my shop on making it all come together and figuring out things on the fly...
Just think of it the ultimate paper in oil capacitor.... Connect an aquarium pump to a hydraulic foot switch, and have several tubes running to various dielectric solutions. Want a more organic musical sound? Pump in some all natural mineral oil. Playing a synth heavy dance tune from the 1980’s? Open the synthetic motor oil valve for that plastic sound. And for the Birkenstock and sprouts crowd, you would of course have a tank of happy sunflower oil in reserve.
1)
Cabinet materials - 3/4 inch white birch. This was the best article I could find
https://www.tnt-audio.com/clinica/cabinet_walls_e.html All seams were secured with square stock and Elmers wood glue and then caulked with silicon latex - Dap ALEX PLUS® all-purpose acrylic latex caulk plus silicone and less than $3.00 per tube. The foam was a 4x8 scrap of "Future Safe" plastic backed dense carpet pad which I bought at home depot for $2.78.. The black closed cell foam which was used to cover the bracing was water pipe insulation around $5.00. The tacky glue was Elmers spray on adhesive. I also used
Aleene's Ultimate Glue and Grill fabric from JOANN fabric $9.99 for a square yard. The interior of the cabinets were sprayed with Clear Liquid Rubber Sealant Coating
https://www.homedepot.com/p/FLEX-SE...iquid-Rubber-Sealant-Coating-FSCL20/300808900 which provides great dampening as well as a surface for tacking down the Future Safe foam padding. I am still working on the stuffing and since there are local sheep ranchers, I can get raw wool for $10.00 per animal. Research dampening was a mind numbing as the capacitors.... But sheeps wool rates very well. Right now there is a small piece of R-19 fiberglass insulation between thin fiberfill batting that was purchased at hobby lobby - Queen Size Poly-Down Batting $14.99
https://www.hobbylobby.com/Fabric-S.../Batting/Queen-Size-Poly-Down-Batting/p/36750
2)
Midrange enclosures - going with highly dampened 6 inch thick wall pvc with the zero to 6 inch mache cone and reverse filled with dense foam and then sandwiched end to end between the rear and front baffles which was secured on the back with liquid nails (construction adhesive offers a durable, flexible bond). This was key, as I wanted the front baffles to be removable and somewhat isolated like the LS3, BC1, etc.. This design also creates a huge central brace between the front and back baffles further reducing resonance. I personally believe that midrange is the most noticeably and emotional part of a speakers and I spent most of my time figuring this part out. When I played IZ (over the rainbow)
the sound is so pure and sweet I almost teared up and that is totally out of character for me.
3)
Crossovers - this was another major piece of the project wading through all the fluff and "fruit forward" reviews of do and don'ts. Really??? The sound of an acoustic upright bass is a complex mixture of a spruce and maple body resonating, of stainless steel strings vibrating on an ebony fingerboard, of callus covered fingertips plucking or resin covered horse tail's hair bowing the strings. With the oil filled Tinned Copper bypass this complex interaction of timbres comes across in an extremely natural manner, so it just lets me get deeper into the music. Only $498.00 each and you need 12... BTW, I measured the yellow 3.5 uf tweeter caps and they matched to within 1 - 100ths of each other @ 3.51 and 3.52 which was pretty amazing. My parts list not including the 16 gauge silicon oxygen free stranded hook up wire.
Dayton Audio DMPC-2.0 2.0uF 250V Polypropylene Capacitor
Part # 027-414 - Tweeters
Jantzen Audio 1.5uF 800V Z-Superior Capacitor
Part # 027-478 - Tweeters
Dayton Audio DMPC-25 25uF 250V Polypropylene Capacitor
Part # 027-438 - Mids
50uF 100V Electrolytic Non-Polarized Crossover Capacitor
Part # 027-354 - Mids
80uF 100V Electrolytic Non-Polarized Crossover Capacitor
Part # 027-358 - Bass
Dayton Audio DMPC-20 20uF 250V Polypropylene Capacitor
Part # 027-436 - Bass
10 Pack .01uf 200v Soviet Military Paper In Oil Guitar Tone Upgrade Capacitors K40Y - for in signal bypass... since i couldn't help myself after reading about all the fruit forwardness from paper in oil capacitors!
Oiyagai 4Pcs 4mm Banana Plug,Pure Copper Binding Post for Amplifier Speaker Terminal Connector w Transparent Plastic Cover.
So right now, its potentially adding some veneers? Tweaking the dampening with sheep wool? And other suggestions that might appear from this forum... Oh, and to not forget, these fasteners for the front Baffles -
https://www.homedepot.com/p/Everbil...Narrow-Brass-Connecting-Bolt-817938/204281651
https://www.homedepot.com/p/Everbilt-1-4-in-x-12-mm-Nut-Brass-Connecting-Cap-818008/204281655
