Thank Youyes...
VERY OLD thread i know...but..this important.Is Euro 240V like US 240V where it's two hots 180* out of phase?
In AU we have Active, Neutral and protective earth.urban areas tend to have the 3 wire option, with L,N & gnd .....and rural areas the 2 wire option..L & gnd.
Shouldn't the power switch get power from the unswitched side instead of switched side ,the way it's drawn in your schematic ? Seems like it wouldn't work the way it's drawn.I have a little time where I can finally get back to rebuilding my Pioneer SX-750. I just finished working on the tone board and since I had access to the power switch I thought now is the time to put a triac in (alternistor on my case).
I did a lot of searching in this thread and after comparing some diagrams I finally found what I needed to do. I made up a diagram for the SX-750.
If you're going to use a triac, keep the snubber cap. If using an alternistor, remove it.
I was able to mount the alternistor to the chassis just in front of the transformer.
Go to the first post and look at the diagram. Mine matches that.Shouldn't the power switch get power from the unswitched side instead of switched side ,the way it's drawn in your schematic ? Seems like it wouldn't work the way it's drawn.
I was thinking that to, but went back to original post, and realized I was wrong, and the switch doesn't actually switch AC, but connects the gate of the triac to the M2 side with a resistor, and the triac sends the AC to the transformer.Shouldn't the power switch get power from the unswitched side instead of switched side ,the way it's drawn in your schematic ? Seems like it wouldn't work the way it's drawn.
Right. I tried it the other way but it didn't work.I was thinking that to, but went back to original post, and realized I was wrong, and the switch doesn't actually switch AC, but connects the gate of the triac to the M2 side with a resistor, and the triac sends the AC to the transformer.
I get it . He is pulling the neutral through the transformer and feeding it to the gate through the switch and resistor.I was thinking that to, but went back to original post, and realized I was wrong, and the switch doesn't actually switch AC, but connects the gate of the triac to the M2 side with a resistor, and the triac sends the AC to the transformer.
They are, but snubber capacitor is not required with the triacs mentioned...I though resistors are not required?
Rather difficult to see the mfg # on this photo.I have a little time where I can finally get back to rebuilding my Pioneer SX-750. I just finished working on the tone board and since I had access to the power switch I thought now is the time to put a triac in (alternistor on my case).
If you wanted to stick with Digikey, post #583 above used this:Should also be fine?
In stock at Mouser:
QJ6025NH5RP
I have placed several orders with Digikey and never been happy with the results. I much prefer Mouser.If you wanted to stick with Digikey, post #583 above used this:
https://www.digikey.com/en/products/detail/littelfuse-inc/Q4025J6TP/216010
That's unfortunate. I've never had a problem with them.I have placed several orders with Digikey and never been happy with the results. I much prefer Mouser.
