Zonker92
All shiny and chrome
Just wire the new caps in place of the old ones, assuming you're leaving the original wiring and L pads in place: Run the green wires through the two 4uFs (wired parallel to each other). Run the orange wires through the single 3uF cap. Run one .01 bypass cap in parallel with the two 4s and one .01 bypass cap in parallel with the single 3. (The pale green wires in the second picture below are the same wires as the dark green wires in the first one.)
If you do replace the L pads or wiring, just copy the original wiring exactly. You will have it sitting right in front of you. You can do one using the other as a reference, or take some photos as you go.
Does that make sense?
