Once a decade if I had to guess.How often do the motors in these need to be oiled?
It will be easy to tell if its been serviced.
i generally find Buyee's Air Delivery shipping very reasonable compared to the alternatives. It's usually shipped via FedEx or UPS in a couple days. Of course, being international shipping, it will never be cheap for a large item. $150-$400 is typical.
I have had a good number of successful purchases through Buyee, and a few that were unfortunately damaged.
I find that the biggest danger when shipping turntables is that some sellers, even ones who do an otherwise excellent packing job, tend to leave the dust cover connected to the hinges on the plinth. This means that if the box receives less-than-gentle treatment in transit, the back of the dust cover has a high likelihood of completely breaking off, potentially causing plinth damage. Some sellers will place the platter on top of the dust cover, which makes this scenario even more likely.
Buyee refunded me half the purchase price when this happened, which I considered fair, as the damage was only cosmetic. In another case, when part of the plinth actually cracked, they refunded me the full cost.
I don't know that I would recommend filing PayPal claims if what they pay isn't to your satisfaction. They could potentially block you from bidding if it causes them any issues. There is always some inherent risk in buying through a proxy shipper, especially if you are relying on the original seller's packing job.
Some Japanese sellers also have the unfortunate habit of leaving the platter in place and taping it down, which may or may not result in bearing damage, depending on the turntable and the treatment it receives in transit.
Seems to work fine. I downloaded the service manual, but it doesn't say anything about checking the oil.
Yes, and that series of JVC/Victor has a sealed drive bearing, no lube should be needed.Can standard Technics headshells be used on these arms?
I’m glad I found this thread. I’ve bought a JVC QL-F4 turntable in excellent condition except from the lid (need a polish) I’ve owned different fully automatic turntable, but somehow this one beats them all in sound! The bass is much better on this one (I’ve came from a Technics SL-Q3) And somehow I prefer a mechanical fully auto instead of the electronic ones. Not so much can go wrong
I put my Denon DL-301 mk2 with a spacer to get correct VTA, it sound amazing!
Love the buttons and switches on this !
I have been looking at Buyee and it does scare me a bit. I live in the Netherlands, how would I go from here? Just get an account at Buyee, find what I like and see how much shipping will be? And who is doing the packaging? Is that Buyee or the intial shipper?
I also looked at Reverb > Unisound and that looks a bit easier.
There are some that say they were born like that, others also believe the earth is flat.however it has the dreaded counter weight sag.
I have the same. I just fixed mine. It s posted up on here somewhere. But basically it’s best to remove the old rubber and replace it with a 6mm thick rubber washer of similar diameter. Mine is now perfectly functional with just a small amount of droop. Was unusable before.Hello,
I have a beautiful QL-A7 however it has the dreaded counter weight sag. Has anyone seen a definitive fix for this?
Thanks much!
Man I just love these. Time to get another 71 or 81 and start on my own. Just beautiful.This kind of custom build is usually done using the TT-81 or TT-101 motor drive units but I found someone that used a TT-71 motor drive unit.
Here is another one.
And how about one using slate for a plinth.
Now, to find a nice clean TT-71 motor drive unit..........
BillWojo
