Thanks desertrat748. If you find that posting please send me the link to it.
I copied the link and put it on my earlier post. Just click on the blue box.Thanks again and yes removing the entire tonearm would be a pain. I'll find your post and go from there.
More importantly you will be happy with the results and performance. I have just the slightest bit of compression with the new rubber. Feels like it dampens quite well.This helps immensely and this old guys like your pictures too.
Thanks!
Mine got to the point where it would hit the base and I couldn’t adjust it enough for most carts. I attempted to take the tone arm off and get access for proper removal of the tailpiece, but the tonearm wires are very thin and delicate. Wasn’t worth all the hassle and risk.It will definitely be better. My counter weight arm sags bad. It's close to touching the tonearm base.
All of it between the bearing housing and the tonearm tailpiece. You can see it on the photos in the help link. This is one of those.I'm for sure not going to take the tonearm off.
How much rubber did you need to remove inside the tonearm so you could get the grommet insert into it?
It shows how there wasn’t anything left over that splined shaft. Not that the tailpiece is rotated over 180 degrees showing the set screw. I thought it was the way to get it off but apparently it’s not. You shouldn’t mess with it as it is really on there tight.Nice! Stanton is also nice! They do perform and fly under the radar!Got a parts QL A7 for 160, Put it back together, adjust the shut off point, done. Stanton 681eee (came with it) and a Pickering micro 4 stylus made by Jico. Just wow, if the price is right, get one.
