JVC QL-?? owners thread
Ya know it's special when you're wife says "wow, what is that?" When you got a sl 1200mkll and a sl1950 with all the spindles in your room. She says play that one please. Band on the run.
Just received my UA-7082 in good shape. Very glad to see it.
However, it have a small sagging starting, I was wondering if a drop of glue at the top of the rubber would fix it because I won't have time to repair the rubber before a long time. The rubber is still in one piece and show no external signs of wear.
All I need now is a separate tonearm pod to hear it whenever I'll be free. I think to craft one myself. According to Victor documents (and they know a thing or two), all tonearms are subjects to mismatched vibrations with the turntable even if they are on the same plinth. To avoid it, the tonearm needs physical link as some Micro Seiki and later high-end Victors does. However, they explained that well-made plinths and bases kinda counter those issues.
Look at Victors flagship models at the time. TT81 or TT101 motor drives in heavy constrained layer plinth with anywhere from 1 to 3 armboards.
Clearly they wanted to tie the tonearm mount to the TT spindle bearing.
BillWojo
On the QL-A75 and A-95, there is an external piece binding the turntable to the tonearm base.
They considered that the plinth have its own vibrations without the binding.
The plinths for TT-101 to 61 are a bit different and maybe they didn't discover it yet or considered it to be harmful. A lot of Victor work was designed to focus on vibrations or issues that could temper the sound even so there was resonances and vibrations allowed monitored by their engineers and computers. Maybe they were simply stronger than the others models. The earlier DD from Victor even had an aluminum tonearm base plate instead of 1975s plinths. They were also low profile with a custom range of accessories including upgraded feet instead of rubber factories ones.
The Victors with the constrained layer base didn't need a brace to tied the tonearm and motor drive together. That base is pretty massive. It also used anywhere from 1 to 3 armboards. Each armboard is a piece of constrained layer wood, simialar to plywood that is 19mm or 3/4" thick and securly attached to the plinth with 4 socket head cap screws.
On my 2 armboard plinth I machined custom armboards out of 3/4" aluminum plate with easy to change aluminum inserts that allow me to change arms complete in just a few minutes. Look earlier in this thread for complete details.
BillWojo
I know about it as I owned a CL-P3 which was too massive, way too wide even by big turntables standards. The dust cover was totally reworked compare to the CL-P1 and P2.
I'll check for the work you did but I think I saw it, my bad.
It will definitely be better. My counter weight arm sags bad. It's close to touching the tonearm base.
Hi, I fixed my droop on the counterweight using a homemade grommet / washer of sorts. If you search on droop here I explain what I did and have pics as well. It took alot of work taking the tonearm apart, but well worth it. I also had a bad wire so I put new wires thru the tonearm as well. Good luck.
Yes, on the ql-a7. I readed the post and started to do mine as well. However, 7082 tonearm is a little different and mine just had the largest rubber which was starting to show weakness.
Therefore, I had to cut down the three others rubbers which were in quite good shape despite the age. When the rubbers are good, it's quite a pita to achieve.
The brass part is still screwed, I am gonna try later to unscrew it, I used some product to help to unscrew it as brutal strength worked to no avail. I don't see how people could remove the top collar from the brass on some pictures as the shapes clearly prevent it.
If 5045 is harder to change, I can't imagine it. Even though it must be easier to remove 7045/7082 rubbers when they are dead.
95B59981-B82E-457C-843A-5283D34E3D65.jpegFC6797AE-588B-4A00-806E-1AA15C1903EC.jpeg635CE8AD-139F-4A66-819F-EC4C5CCE4AFF.jpegIMG_4331.jpegIMG_4332.jpegIMG_4333.jpeg95B59981-B82E-457C-843A-5283D34E3D65.jpegFC6797AE-588B-4A00-806E-1AA15C1903EC.jpeg635CE8AD-139F-4A66-819F-EC4C5CCE4AFF.jpegIMG_4331.jpegIMG_4332.jpegIMG_4333.jpegIMG_4334.jpegIMG_4336.jpegIMG_4337.jpegIMG_4338.jpeg
I had a bit of sagging on the visible rubber, but I regret I took it down as internals rubbers were perfectly fine despite a bad alignment of the collar with the time.
I am gonna purchase a set of rubbers to replace the three rubbers. I can mesure the two of the back, but the one doing a joint with the tonearm will requires that I mesure the inside of the collar.
I think it was still factory rubbers as the inside collars one had special square cuts.IMG_4339.jpegIMG_4340.jpegIMG_4341.jpegIMG_4342.jpegIMG_4343.jpegIMG_4344.jpegIMG_4345.jpeg
I am wondering if it wouldn't be much easier to actually buy some rubbers, make a side cut with a stiletto, and insert them inside.
That looks like it now that you say it. It was kinda full of a special glue in the brass section and few others places, making it harder to move, never saw any mention of it.
However, as I can't mold it, I gotta make it in several ones including a top head reworked to manage the squares. I am gonna see if I go for urethanes or not, I checked prices and it's about 28 euros per part in my country. I won't go for urethane for the top model with the square crown as I can't rework it.
I am glad it's over and removed the glue for the next dismantle.
Can't wait to finally listen to it.
Yes, but the rubber was totally undamaged, and factory part.
I'll post later also pics of the Victor ceramic turntable weight. It looks unusual, but it works very well. However, it is extremly fragile.
I recently took a chance on this Victor QL-Y7. When it arrived the platter would start to spin but then stop again. The series of switches along the front panel seemed erratic so I squirted them with contact cleaner, whereupon the whole thing stoped working completely. I managed to get one of the switches apart, and the little metal contacts at the bottom were corroded, so I cleaned them up but it made no difference. Sticking a meter across them (removed from the PCB) reveals the resistance when energised ranges from 200 to 400Ω. I figured they were shot, pulled them out and replaced them with new parts, albeit of an entirely different design.
I've replaced most of the electrolytics in the deck now (just waiting for a couple I didn't have). Some of the larger main supply ones were toast.
The platter now turns again as soon as the turntable is powered up, but none of the switches do anything. The two on the motor unit itself, which select 33 or 45rpm, are touch switches which apparently rely on capacitance to work (except they too are unresponsive). I'm assuming the ones on the front panel aren't, as they're plastic, but the fact that the little nipple inside them that bridges the gap between the two metal contacts is made of a rubbery material is making me wonder whether there's something odd about these switches. Does anyone know what the score is with them? I might reinstate them, having now cleaned them all (they're a fiddle to get apart).
This is a great video of a different model. He troubleshoots it and gets is working. Skip to minute 26 if you want to go directly to the switch disassembly and replacement.
I've managed to wake it up! I removed the new momentary switches I'd fitted and, after carefully cleaning the old ones, refitted them. That and a recap has got it going.
Have you tried pressing the buttons with a damp or wet finger?
Check if the buttons work with this method.
They're not conductive, unlike the ones on the drive unit itself. It seems the circuit somehow took exception to switches that read 0Ω when closed, rather than the 200-400Ω of the originals.
