I would suggest buying a working Shure body and get a Jico SAS/B. This would run around $250 depending on how patient you are when selecting which shure body to get. If you can get a V-15 type IV that would probably be great. Though, a M95 or M75 would be fine as well. Typically, from a Japanese seller on ebay, the Jico SAS/B stylus is around $230 shipped to you. I have a Shure V15 V with a SAS/B stylus(That was around $400 total) but I also have a VN-45E stylus that to me sounds extremely good. With the Vn-45E stylus, the total was $200. Also, there are plenty of AT VM540ML new on ebay from reputable sellers for less than $300.Happy New Year, everyone.
Just got a QL-Y5F and am looking at either replacing the stylus or possibly a new cartridge. It came with a JVC Z1 cart and a cheap conical replacement stylus. For a stylus I was looking at the jICO SAS but their website states it's only available for shipping in Europe. Was looking at the AT VM540ML as a possible new cart. I don't want to spend much more than around $300 for anything. With my age and hearing it won't be worth the money. I'm using a Denon AVR-3600 to hook it up to.
Any suggestions??
Thanks!
The cuing mechanism takes a heavy duty fluid, it not oil per se. It's the high viscosity of the oil that slows the cuing action.Hi JVC QL-xx owners!
I just got a QL-7 in a bundle with a Sansui AU-717/TU-717 package, and it seems like it will be excellent! I would like to do some maintenance on the table, and maybe veneer it. Not sure how to set the tracking force and anti-skate, need to add oil to the cueing mechanism, might re-cap the drive and try to fix the counter-weight droop. Any other suggestions?
I would like to get a copy of the manual, but unfortunately my Vinyl Engine account got deleted after a period of inactivity and now they are not allowing new registrations. Could someone please post or send me a copy directly?
Thanks!
I have a VM530E on my QL-Y5F and like it quite a bit. It's balanced and pretty neutral without being boring and analytical, if that makes sense. Still plenty of detail. I imagine the S even more so. I don't remember why, but at the time I was looking at 540's, the deal on the 530 popped up and someone suggested that would be a better cart for the QL overall.Happy New Year, everyone.
Any suggestions??
Thanks!
Do you have a multi meter? Going to need to find out what has power and where it doesn’t.I’ve just discovered this QL owners forum. I have a QL Y 55 F which until recently was running just fine. So now the tone arm side of the table has lost power ( control panel and speed led panel ). When I press the power on button the motor starts turning by itself and that’s it. Any advice or help on this issue ? I’m living in Ireland so I am using a transformer for 100 v and bought a pretty decent transformer so I don’t think this caused the problem. Any help ?
Definitely. Worth it. I just don’t have any experience with your particular model.I have a multi meter I’ll do a check. Worth asking on this forum what issues or faults other owners have come across.
I have the same table and have used many different carts over the years and settled on a Nagaoka MP110H (with headshell).Happy New Year, everyone.
Any suggestions??
Thanks!
Anyone have a complete TT801 system with vacuum pump and dedicated mat?
Pretty sure you're aware at this point options are limited.
First I would open up the bottom and make sure the motor is mounted correctly, etc. I couldn't tell if it was the spindle moving or the whole motor from the video. If you don't get much help here, I would post a new thread. Outside of JVC enthusiasts (of which there are maybe dozens worldwide lol) this thread doesn't get much attention.new to me JVC QL-A7, seems to have a serious spindle/motor issue, haven't opened it up yet, wanted to check first if this is likely going to require machining (because that's out of my skill range). All the buttons work, the brake engages, but the platter doesn't move at all and obviously the spindle is wobbling. Other issues are the counterweight droop and it's missing the bottom plate (neither are a big deal). Any thoughts appreciated!
