mcdoug3721
I would guess that plug A is still installed. Seems likely that the short is on the main amp board if R301 is lifted and pre-main jumpers out. Hard to tell since there has been no confirmation as to the status of plug A.
I think it was pulled earlier and we still had a bright bulb. Just wanted confirmation it it is still out.I would guess that plug A is still installed. Seems likely that the short is on the main amp board if R301 is lifted and pre-main jumpers out. Hard to tell since there has been no confirmation as to the status of plug A.
That leaves only the 24v to pin 3 on main board if plug pulled and R301 in place. Unlikely in Tuner. Like to see some voltages.I think it was pulled earlier and we still had a bright bulb. Just wanted confirmation it it is still out.
I need you to confirm that the plug on top of the chassis is not presently installed. And that anything else connected to the + terminal of C301 is not connected.
A picture showing the bottom of the chassis with the socket and diodes and the cap all visible would be helpful. Don't be shy using pictures.
The ESR of that cap is pretty high, but that won't make it draw lots of current continuously.
plug "A", R301, C301 disconnected.I need you to confirm that the plug on top of the chassis is not presently installed. And that anything else connected to the + terminal of C301 is not connected.
Yes, I have a multimeter, c301 is connected with a wire with jumper A, unsolder it? I thought it had no effect...Based on post 45, the jumper plug is removed. The positive wire from C301 is still connected.
OP, do you have a multimeter to test continuity and voltages? The component tester is great for spot checks, but is not effective for the types of tests that are now required.
Yes I was wrong. I though it was still connected, not I see the end of it. Previous post corrected.Yes, I have a multimeter, c301 is connected with a wire with jumper A, unsolder it? I thought it had no effect...
Yup C301 is the likely culprit. Possible diode yet unlikely given that they rarely go bad. I believe they were checked and appeared to be good? A new 4700uf cap will likely take care of things. As far as cutting wires, it is a extremely rare case where I would cut rather than desolder. Even wire wraps get unwrapped and rewrapped in most cases with some getting new wire. Depends on the unit.@mcdoug3721 He did a DBT test with C301 disconnected (cut wire) and there was no problem. DBT dark as to be expected with a good bridge and no cap to charge.
It could be the diodes or the cap failing under voltage/load. At this time it is not clear. My gut says the cap, his tester shows a pretty high ESR, the uF value is close.
I don't trust those universal testers for larger value caps.
Yeah cutting wires is quick and easy but not recommended for several reasons.
You may not have enough lead length to put it back. (big red resistor)
It is harder to unsolder and remove the tail you cut off now that you cant get a hold of it to wiggle free.
It may leave wire bits as @mcdoug3721 said.
Same. You are going to have to put an iron to it to clean it up and reattach the wire.it is a extremely rare case where I would cut rather than desolder.
I did that, too, up to the point of buying a used wire wrap gun at a swap meet. But then it occurred to me that wire wrap was done for the benefit of the assembler (faster, one tool, no heat time, no cool time, etc.). It also made service more difficult than soldering. Now I resolder to the wire wrap post. Some may find it blasphemy, but it makes future service easier.Even wire wraps get unwrapped and rewrapped in most cases with some getting new wire.
Thank you for the tips, I try to cut as close as possible to save the wire so that I can solder. I exchange c301 and come back with information.@mcdoug3721 He did a DBT test with C301 disconnected (cut wire) and there was no problem. DBT dark as to be expected with a good bridge and no cap to charge.
That will be OK for testing. Leave the plug out of the chassis jack for now.before it starts, I want to make sure, I connected the new C301 to R301 and brought out D1-D4, is that ok? for now such test connections, plug "A" stil disconnected
there is progress, a light bulb flashed and dimmed...That will be OK for testing. Leave the plug out of the chassis jack for now.
