Can you tell me what you mean by 'movement of the scale'? Volume control?
It's been a while, and I'm lost. I thought it the short was solved and the amp was working. Can you summarize how we got here and the work you've done? Listing them in the order you did the work will help.
Which caps did you replace in the tuner? It helps others who experience the same situation.
Specific thoughts:
- Ia that a 1/4 watt resistor? The original was 1/2 watt. May spell trouble.
- R945 seems to be the emitter resistor for the driver transistor Q1. You will need to pull it and test Q1 (and probably Q3, too). The original is a TO-66, so a TO-220 will be a replacement, if needed.
- C921, 922, 923 and 924 have been replaced. If the installed caps don't match the schematic, replace them with correct ones. Mine are the same as the caps listed in the service manual.
- Q7 has been probably been replaced. Given the attention to detail from the other repairs, it worth checking if the replacement is a good selection for the job.
- For the PCB trace, check it with a meter for continuity. If it's not good, bedn a cut-off capacitor lead and solder it over the existing trace. Regardless, that solder is worth removing (solder sicy or suction) and reflowing.
After you get all the other things working, you can improve the sonic quality by doing the following. It is usuallr recommended that improvements shuld wait unitl all problems are completeely resolved.
- Replacing the 2SC458 ttansistors with KSC1815 or KSC1845. The 1815 is lower gain, but the KA-6000 has an odd gain structure and the 1845 can create some minor problems. Experimentation is key with thei amp.
- Replace all the 1/2 watt carbon comp resistors wiht metal film
- Recap and use film caps for values under 3uF.
