KLH Model 9
Thanks for suggesting uship.com, which has worked well for previous shipments of large tape recorders and furniture I've sold on eBay.
Regarding shipping, David advised removing the power supplies, which he explained was a relatively simple procedure involving basic hand tools. No melting of wax needed!
On the topic of the power supplies, if they remove so easily, are they also easy to test for the correct voltage when removed? If so, what is the procedure for PS testing?
These belonged to an audiophile born around 1945 who is no longer able to enjoy them. There is also a set of amplifiers that I have not inventoried or explored.
I had a chance to listen to a pair back in the 70s; they belonged to a local audiophile who definitely knew what he was doing when he set them up - he spent a lot of time positioning them and even searching for an amp which worked well with their finicky load. Of course, these were the original design and they suffered from the known issues of the Model Nine: limited volume, arcing and thin bass. I am not and never have been someone who has to play their stereo loudly, but these units were definitely not for rock music or even dynamic classical compositions. When I asked him to play them as loud as he was comfortable with, the poor owner complied but was constantly hovering near the volume control during the louder passages (it was fairly non-demanding orchestral music). We probably weren't near an 80 dB level yet but they were right near their limits. I could tell he wasn't happy with the volume limitations either. :) It did make it hard to assess their sound, though, because a lot of the detail was buried at the levels we were able to achieve - and I'm sure the bass suffered as well. The more bass in the recording, the more he had to restrict the max volume.
Hopefully, the new models are capable of more output without damaging the panels. What I heard was intriguing, but definitely not a speaker I could live with.
Alright, I’ve been reading a lot for a couple weeks and now I’ve got a few things I’m looking for clarity on.
First, I have a pair of nines that were my grandfathers. He actually had 3 sets, but I only recall ever seeing 2 sets. My understanding is that an earlier set he had were a bit bigger which makes me wonder if they could have been prototypes. He was a professor in Boston so anything is possible given the history of KLH. Growing up, I had no appreciation for what he had, they were just huge speakers that only ever played classical. As an adult, I sure started to get it and it’s all I ever hoped for when he passed... and he left all the audio stuff to me. Well, almost everything. Someone took the turntable, music and CD player. Trying to get it back...
So, I have an Acurus a250 (250 @ 8ohms) amp, so I should be supplying 125 to each 16 ohm speaker. Feel free to correct me if I’m wrong. I’m sure my other readily available option is too small. That’s a Denon DRA-75VR
Thanks for the tip E-stat. How much more room? I've been trying to figure out how to best utilize the space to accept these and look/sound good where they'd be used the most. I thought about moving the Pinnacles to the outside of the subs. Once I get a layout I like, I'll start wiring up everything again.
In a perfect world, I've found a tip from one of my mentors serves quite well. He calls it the "Rule of Thirds". Place them one third the room length away from the front wall and separate them laterally by a third of its width. Fine tune final position by ear and measurements afterwards. Those guidelines optimize imaging, but more importantly minimize room modes from affecting the overall response.
Having said that I fully appreciate that's not always possible in everyone's space! So much of a dipole's character does reflect (pun intended) the notion that an equal amount of sound radiates from the rear. You must help guide it to provide a smoother response at the bottom and you don't want to throw it away. Lucky lad that I am, I'm able to give my large Sound Lab stats such an environment. One generally accepted rule of thumb is at least three feet. In our HT system, that's about what I'm able to give a smaller pair of Acoustats given it lives in the family room.
I prefer arrangements where the gear can be located decidedly behind the gear or off to the side. Having a massive cabinet between speakers always compromises the center fill and perception of a consistent left to right soundstage.
I've got my nines wired up and playing on my Denon for now. They sound great even with a fairly small power source. Unfortunately I've also figured out that the upper left woofer in the right speaker isn't working. Will have to start digging into why. Sitting down and listening I couldn't even tell that a woofer was out. Not perfect, but not far from it either. Now I need to play with placement and decide if I'm going to sell the Acurus and get an amp that's more like 75wpc @ 16...
WMassGasMan, from experience, I have 6 pair of KLH Nines, I can tell you they like some muscle. It is also common for their tweeter panels to fail. Further, there is a diode ladder in the potted power supplies that age and should likely be replaced. However, when fully working correctly, they are magnificent. I would suggest a big tube power amp or even a ss unit.. Rouge Audio M-150 would be a great match..
There is a pair of Nines for sale in Westwood, MA which I've linked to in Dollars and Sense.
Tim
