KLH Model 9
Well, I'm really striking out with U-ship this time. The first time I tried, I had a bunch of bids between $200-$350 to transport them. Unfortunately, the person I went with dropped of the face of the earth, so I had to cancel. After re-listing it, I've only had two bids ($600 and $1200). I hope the ebay seller doesn't lose patience with me.
They're finally here. The good news is they they're complete, unmolested, and in good cosmetic condition. The bad news is they don't work, but that was expected since they were sold as "untested".
Initial inspection reveals that two of the power supplies aren't working at all, and two work, but the voltage is low, but that's also expected. I already have some 4kV diodes to replace the seleniums.
They've definitely been played hard. The transformers have been hot enough to melt some of the wax, and the 1A fuses were replaced with 1.5A. I hope there isn't too much damage to the panels or transformers.
The bass panels I've looked at seem to be suffering from open connections where the bias supply terminal is riveted to the plastic frame. It's supposed to make contact with conductive paint on the inside which makes contact with the diaphragm, then a second terminal takes the bias supply to the next panel (there are 10 bass panels). On many of the panels the connection between the two terminal lugs is open circuit, so none of the panels down stream from the first open are getting any bias voltage.
I haven't opened any of the panels yet, but there is some corrosion around the rivets which I suspect has broken the bond with the conductive paint. That should be easy to fix if the diaphragms are ok. I'll know for sure soon. Fortunately, the bass panels are easy to disassemble.
I've already drained the wax from one of the power supplies. It wasn't that bad using a 200 degree oven and a large pan to catch the wax.
If nothing else, I'll end up with some nice looking mid century modern room dividers...
I'll add some pictures soon.
I've discovered some interesting things about my power supplies. They don't exactly match either of the schematics attached to post 56. It comes closest to the updated schematic, but there are a several differences. R8 is missing, and R7 is 22M, not 2.2M (probably a typo). The big difference is that all of my power supplies deliver a positive bias voltage. Did KLH change from positive to negative during the production run? Is there any advantage to one polarity over the other?
Post #65 - most interesting pics I've seen in a long time. You're a brave man, tackling that. I hope you get these guys figured out and up and running.
So far so good. I've got two speakers basically working with the two semi-working power supplies.
The failure mode for the tweeters is the connection to the diaphragm. They are impossible to disassemble without great risk of damage, but I was able to restore that connection on one tweeter with some conductive paint.
The woofers also seem to have an issue with the conductive paint that connects to the diaphragm, but fortunately, they are easy to open. Inside there are carbon traces that have degraded and now have numerous breaks. I've ordered some carbon paint to try to repair them.
I put new diodes in the power supply from my previous post, and replaced those burnt carbon resistors you can see in the picture. This has restored full HV (more than full with the silicon diodes). Instead of adding a resistor to reduce the output voltage, I'm going to install a bucking transformer to cut the line voltage by about 10%. I plan to leave these connections exposed so I can play with the voltage in the future if I need to.
The actual drivers are pretty robust, and CAN be rebuilt if they fail by folks like Janszen, ESL Repair, or ER Audio. The tweeters are standard JansZen pieces, so not at all hard to find replacements (used in most old JansZens & quite a few others... RtR panels will work as replacements as well). Those woofers however, were proprietary. I have a full set of spares - both woofers & tweeters from a rough pair of Nines I picked up years ago without any power supplies. I haven't even used my working Nines in several years, so I can't see any reason to hang on tightly to so many spares!
If you find you need a few, PM me.
Thanks for the offer, I'll probably take you up on a few woofers. I'll see how I do repairing the woofers on the second pair. I have two spare woofers that I bought from ebay after I won these, but before they arrived. So far, I see only one that will probably have to be replaced (due to corrosion). I won't know about the rest until I open them. They'll wait until I have the first pair fully working.
My parts arrived today. I decided to go ahead and just replace all of the resistors even though they still test good. I don't want to have to melt the wax out again just to replace a 20 cent resistor!
I'll be keeping an eye out on ebay for tweeters since they seem to be much harder to repair, and I don't know how reliable my fix will be long term.
Does anyone know exactly what they are potted in? I don't think it's wax. It smells more like pine rosin when it melts, and it it's harder than wax when solid. It's VERY sticky and difficult to remove even from glass and smooth metal. It's a little scary handling a large amount of it when it's molten at 200 degrees!
It's been a while since I've posted, but I'm still working on them. I'm almost finished with one pair (including the power supplies). I'll post more detailed progress and pictures soon.
These speakers seem to be a lot tougher than people think. All four of mine show signs of being driven really hard. The resistors in the tweeter network have been so hot that they melted and discolored the plastic mounting plate. The transformers have been so hot that they have melted a significant portion of wax (the worst one is in the attached picture).
I've been listening to the first pair (which worked with only some minor repairs). Even when listening for several hours with as much volume as I care to take, the resistors and transformers don't even get warm. Based on the dire warnings I've read about serious damage from playing them slightly too loud, you'd think the panels would be burnt to a crisp by now. In the pair I've been working on, the worst damage I've found are a few microscopic pinholes in a small number of the panels.
It's been a while since I've posted, but here's an update. I ended up with one bass panel that was badly damaged from moisture. It had heavy corrosion on the stator and the membrane was ripped. I used one of my two spares to replace that one. There were several more with some pin holes near the edges which I was able to repair.
The main cause of failure was the conductive ink that connects the membrane to the HV. Except where there had been arcing, the ink traces looked fine, but measured open circuit in many places. I suspect microscopic cracks had developed in the ink. On some, the open section of ink arced and burned holes in the membrane at the edge. For those, I was able to patch the small holes with glue and patch the conductive coating. I repainted the conductive ink traces on all of the drivers.
Another problem I found was that about half the drivers had large dead spots where the membrane wouldn't charge. On some, only half the driver was working and output volume was noticeably lower. I found a great deal of variation in the carbon coating on the membranes. They clearly tried different methods to apply the coating over the years. The older set has a relatively thick coating sprayed on. For most of these the resistance was quite low (and measurable with a DMM).
The newer pair has a brushed on coating with much higher resistance (measured open circuit). Even those had wide variation in how thick the coating was. I ended up spraying a very light coating of carbon paint onto the problem membranes. This immediately restored full output when I tested the panels individually. I know that in theory they should have a very high resistance coating, but Janszen used a relatively low resistance coating on both the older woofers and all of the tweeters.
I used MG 838AR as my conductive paint. When I needed to brush it on (to repair the ink traces and stator coatings) I sprayed some into a small container.
http://www.mgchemicals.com/products.../838ar-total-ground-carbon-conductive-coating
Apart from that, it has been mostly mechanical work, and cleaning. There were some open resistors in the tweeter networks, and one shorted HV cap in one power supply.
I have a pair of the Nines that I bought from Hi Fi Classics of Far Rockaway, NY in Feb '92. The cost was $500 and I had to hire a van to drive down and pick them up for return to my home in Old Greenwich, CT. I discovered them by sheer chance. In July '91 I was looking through the NY Times Sunday and its "Merchandise for Sale" section. For you youngsters this was before the Internet became widely available and the search for audio gear relied upon print: ie, newspapers, magazines, and AudioMart. The ad from HiFi Classics offered TWO pairs of Nines for sale, $500 a pair, original owner! So I called them on Monday and discussed purchase of a pair. I ended up sending them half the amount ($250) and paying the balance upon pickup. They agreed to hold a pair for me. Unfortunately I was unable to arrange transportation until Feb '92 (my birthday in fact, Saturday the 16th!). Quite a nice present to myself! Yes I did arrive safely home with a nice pair of Nines in excellent cosmetic condition! And in excellent working form, too! They have remained with me as my main speakers through all these years. Their only serious competition came from my Quad 57's. The 57's sure sounded nice, but on large - scale music (like some Mahler!) and rock (Moody Blues, Hendrix, Floyd) I preferred the greater dynamic punch of the Nines! END OF PART 1: coming up - how I came to be aware of the Nines and my subsequent journey into Audiophilia!
Congrats on the KLH Model Nines!
The first Nines I heard was in the late 60's. They were playing a tape of a live session from a supper club on a Magnecord tape deck. I do not remember which electronics, but the dealer was a Fisher fanatic, so the electronics were probably Fisher.
What really impressed me (as a "wannabe" musician) was that I could hear the silverware clinking on the customers plates. That was a sound I remembered from my short experience playing in jazz supper clubs (I quickly realized I was not good enough to quit my day job!).
That has been the ONLY time in 50 years that I could hear the sound of customers' silverware on their plates from a supper club recording!
I know of no other speaker that would have that clarity in the treble range!
Congrats again on the KLHs!!!!
Thanks
Jim
I don't plan to let these go in the foreseeable future. Now I'm curious about other vintage electrostatics. One in particular is the Pickering Isophase. Has anyone ever heard them?
Somebody just gave me a pair of these "klh model 9 full range" in mint condition said he had no idea what they were I figured I would just throw them out of my patio for a little extra sound but I don't have a power supply any ideas on where I can get the power supply?
Welcome to AK! If the 9s you were given are truly in mint condition you should take the friend that gave them to you to dinner. And buy some lottery tickets while you are at it!
The little dirty but he was planning on throwing them away said somebody gave them to him but he didn't have the power supply I told him I would put them in my garage so when I was working on my car as I would have some sort of music but without a power supply they're worthless to me
I don't know these speakers but someone here will be able to help. I do know a bit about the Janszen electrostatic tweeter panels that are in them. What do the power supply connections look like?
It looks like a normal two prong but an extension cord won't fit in there
