KLH Model 9
Pictures, yes they have seen better days...
I have seen far worse. After plugging them in you should wait about 24 hours before using them to allow the ozone layer to stabilize. Amazing to see speakers in this condition considering these again the tome made were about the most expensive speaker you could buy.
considering these were on their way to the dump, I feel good about my intervention.
I just hope they don't end up being a BPITA...
"Dust is their worst enemy."
Should read "hopefully, dust is your worst enemy"
I still remember years ago there was a set in Boston sent to be serviced that had cockroaches.
I just hope they don't end up being a BPITA...[/QUOTE
If they are, I bet there are any number of persons here willing to relieve you of them. You should feel wonderful to have saved them. These are example of equipment that should never end up there. There were never that many examples made to begin with. I can not remember exactly, now but, seems to remember less than a couple hundred sets. I used to know.
As for whether dust is their or your worst enemy my thoughts are this:
Whether you own them or not dust is their worst enemy.
Dust is your worst enemy in this case only if you own them.
incredible speakers i had the luck of hearing. i have been trying to get a pair of a friend of mine. he has two pairs that he never uses.
" i have been trying to get a pair of a friend of mine. he has two pairs that he never uses"
The bribe is still insufficient
I better get back to the two pair my bud gave me some time ago. Started rebuilding the power supplies and that's where the are now.
Has anyone done this here that might share their process? I have the sometimes vague rebuild article from an 80's Speaker Builder, but it IS vague.
Never tried it myself but I think there is a thread here on it. The most difficult part is getting the best wax out. Seems a hair dryer and repeated hearings is the way to go. Save the wax as the person supply needs the weight to hold the speaker up. I understand the selenium is a mistake replace, I would just replace every passive component and if you'd u do not have the oem account cords flace the account connector. Check the wiring to the pin connectors as it may become brittle and reflow all solder joints. Art did not use complicated power supplies. Biggest challenge is if the transformer is bad. In that case maybe David has a substitute. I used to rebuild the JansZen speaker power supply/crossover and surprisingly even these were simple.
Hi
I just finished rebuilding a set of Nines that exhibited some hum on a couple of bass panels. De-potted the wax to replaced the selenium , found out they were replaced already. Upon reassembling had lost high voltage somehow, Found out I wired one of the rectifiers backwards. Had to depot the wax again and redo the rectifier array. Still no high voltage. Changed a transformer, checked all caps, checked rectifiers again and reassembled. The hum remained. Cleaning the bass panels to "reduce leakage" solved the problem. Now both work well with no hum. Thanks to David Janszen for pointing me in the right direction! How simple that turned out to be! Despite all the negative comments I've read and heard from people over the years about these units (maybe because they really haven't heard or owned them and they just perpetuate negative comments they have read elsewhere), these speakers are very musical. Ive owned SL A-3, Maggie's, ML CLS-z and currently zA2.1 (air-layer). I just love the Janszen designs. tonight I'm going to run the KLH-Nines with a Futterman H-3a amp (the original Julius Futterman design, not a NYAL design). Should be fun!
Made some progress on two of the 4 KLH Nine Power supplies this past weekend - Now have the two working and tested both the tweeter and woofer outputs proved good - Though I experienced that 1 of the 2 spare woofers i tested had notably less output than the other - I bet I need to clean it - or possibly its holed or fried. I have some brief notes from or at least BY David Janzen on cleaning, but wanted to get your input (Ha!) on it. I have had the PS cans de-potted for 10 years or so, and initial re-build was not successful. A Pal and I tested three HV voltmeters together- one an electrostatic VM, so we re-did the bungled rebuild and it worked. Excited to be that much closer to HEARING the Nines soon -
There's a local Doctor of Chemistry at our University that has a pair he's owned since new. He drove them with a 2105. He has had them repaired twice I was told when I saw him around Christmas time. I forgotten what amp he is using now, but he said he was as happy as ever. Sweet muted highs, lots of clarity, but very little bass. Any speakers clarity will improve if you curtail the bass, its an old trick. Attenuating highs will reduce fatigue factor, too.
On cleaning the woofer panels -
rdiiorio - how did you do this?
David Janzsen mentions using diluted ammonia WITHout any detergents, and I assume a distilled water rinse so nothing is left that can conduct, and then drying in a closed container with desiccant -
So far with the exception of science / chemical supply houses, all of eh ammonia I can find has detergents / surficants in it -
Any tips or experience would be most welcome.
Congratulations, well bought!
That's a very good price for a double pair that look to be in good condition. Some day I need to pull mine out of storage & freshen them up. KLH Nines are truly among the best when working right.
