Not sure if you are serious... as stated this seems, to be nice, a silly question.
Thanks for the thoughtful response. I never had these type of speakers so I am looking for support from others so I can get this to work. I have the Model 6 speakers without the 3rd terminalNot sure if you are serious. Rephrase the question, because as stated this seems, to be nice, a silly question.
If you really mean what you asked, then of course it needs to be hooked to a receiver and some type of source. For example CD player, turntables etc.
Thanks for the link...pretty extensive. What did you apply to the woofers for a sealant?Good information. I have to say though, those terminals look bent. Are they wobbly? Beneath the plate, sits an epoxy tub encasing the crossover. Due to age, it’s become very brittle, and if the terminals were bumped against some of the epoxy broke up a bit where the screws go into it. Not a big deal, just info for you. I would strongly suggest recapping these. You’ll need to remove the aluminum plate, break up the epoxy tub to expose the caps and three way switch, and to gain access into the cabinet. There will be an 8uf cap, strapped to the front baffle, which will need replacing. On the crossover itself, will be single cap, that’s actually two caps one package.
Another issue is the woofer surrounds are fabric, and we’re sealed to be air tight. Over the years, it dries making the surround porous, causing pour and flabby bass output. You may be lucky that your have removable grills making it easy to apply new sealer, restoring the excellent bass output these are known for.
I have a set circa 1963 that I did a complete restoration on, and they are amazing speakers.
Here’s the link to the restoration you may find helpful. BTW, the model Seventeen has the same crossover, so any reference to the Seventeen will apply to the Six.
Cheers, Glenn
https://audiokarma.org/forums/index...-original-1963-owner-pics-restoration.520806/
eBay seller “vintage-ar” sells the sealer. It was developed by Roy Champaign, and matches the original factory sealer. Roy makes it for vintage-ar.Thanks for the link...pretty extensive. What did you apply to the woofers for a sealant?
Thanks for the feedback. Yes the grills come offeBay seller “vintage-ar” sells the sealer. It was developed by Roy Champaign, and matches the original factory sealer. Roy makes it for vintage-ar.
Have you checked to see if you grills are removable? Make sure you unscrew the KLH badge before attempting removal.
If yours are earlier like mine, then the grills are glued to the baffles and not removable. Some cut the fabric to access the woofers, others actually have removed the front baffles from the cabs, removed the fabric, sealed the surrounds, and reinstalled the fabric and baffles. Lots of work, but doable. Luckily, the grills were already removed on mine, and eventually I found removable grills on fleabay.
Negative (-) from amplifier goes to ‘amplifier connect’, positive from amplifier (+) goes to BOTH the other terminals.I just picked up a pair of KLH model six acoustic suspension speakers. Do I need to have the 'amplifier connect' connected for it to work? Thanks in advanceView attachment 2472365
Lucky you! Everything much easier to restore then. You’ll still need to break up the epoxy tub though. It’s very brittle, shouldn’t take long to do. Post some pics when you get a chance.Th
Vintage Acoustic Research connectors were labeled even worse. “1”, “2”, and “T”.KLH could have labeled the connections a little more clearly. It would be easy for a user to think the "C" terminal meant "common". Of course, if you have the instructions, fine, but they aren't always there.
Doug
I have been reading and enjoying the wealth of information available on the threads in this forum regarding all things KLH, but this is my first posting on anywhere, and fear I may be asking a question in an incorrect place.
I just received a pair of KLH 6 cabinets with the crossovers and fiberglass. No woofers, tweeters or grill panels. These were added to a craigslist purchase of a Sansui FR 1080 turntable that I wasn't convinced was what I really wanted due to some issues with said turntable. These cabinets were offered after he showed me a really nice pair of KLH 6's he just restored when I mentioned that I was trying to create a pair of cabinets to mount a set of KLH 17 components from a set of KLH 17 sized cabinets I created earlier which did not turn out the way I had hoped. I made the new cabinets sized for the KLH 6 hoping to see how the difference in size would contribute to the sound compared to the KLH 17's I recently acquired.
I had read here that the difference in lower bass was slight between the KLH 6 and 17. I can relate that the KLH 17 woofer and crossover, but with a PE Express Phenic Ring Tweeter, installed in the KLH sized 6 cabinets that I built, do indeed sound deeper, cleaner and punchier overall than the Bonafide KLH 17's, with all original components
Now that I had the actual KLH 6 cabinets and crossovers I now naturally want to build a real pair of 6's. But before I started to venture down that road I wanted to check if the crossovers were okay which leads me to my questions.
From what I have learned (correctly, I hope!) on this forum, the crossovers for the KLH 6 and KLH 17 are the same except for the .4 mh inductor coil for the woofer on the KLH 6. When I connected the KLH 17 woofers and tweeters to the KLH 6 crossovers, cabinet 1 read 2.1 ohms on all 3 tweeter settings and cabinet 2 read 2.4 ohms on all 3 settings. When connected to my SONY STR-6055 receiver, both speakers played fine, woofer and tweeter, but I could detect a faint clicking form the tweeter. Fearing the worst, I disconnected the amp. I then checked the resistance without the inductor and cabinet 1 read 8.1 ohms and cabinet 2 read 8.3 ohms. These readings were consistent with the readings from the KLH 17 the drivers came from. Both played fine when connected to the amp with no clicking detected.
Is the lower resistance reading normal?
Does the inductor lower the overall resistance?
Could the inductor be defective?
Is the KLH 17 woofer contributing to this change?
I am trying to find KLH 6 woofers and tweeters to complete this "Restoration" so I can see what REAL KLH 6's really sound like!
