Klipsch Modifications
A $55.00 kit with about $5 to $10 dollars' worth of parts and I'm being generous.
All the bovine sediment concerning "matching transfer functions" is nothing more than a higher ESR, (equivalent series resistance) in the capacitors vs. the cheaper Daytons.
If you get modern, large "motor run" capacitors, full of inert oil, they have, essentially, the same capacitor materials, as the inexpensive Dayton Film Capacitors inside (I purchased a few).
The oil is for "cooling the peaks" during motor starts, which are way more demanding than the Milliwatts required to drive high impedance Horn Drivers!
Also, going through the Klipsch T2-A Autoformer/voltage divider, as a "worst case" scenario (least attenuation for AA vs. Heresy or Cornwall Crossovers) means that the Drivers will NEVER see the 10 volt PEAKS that would result in Khorns or LaScalas generating 121 db of output that would make your ears bleed.
The net result of JEM capacitors vs. cheap Daytons is the difference in "sharpness" or "dullness" difference, which is Audible, unlike the "Youthman conclusion" from the Video.
There is magic in them... Klipsch blessed them so they are holier than thou. :jump:
We do not need to make fun of others opinions here (but maybe that's your thing). Especially the man in charge of design after "The Man" passed on.
They are just 5% mylar caps and no secret sauce but that OEM endorsed price tag.
And the other Crossover guys giving away there stuff for cost ? Sounds like you have a agenda vs Klipsch ? ;)
Is he in trouble for telling the truth? Some people did not invest $600 in an ESR meter like he did.
I'll do the jem recap for now. What's the deal with the alk's? What do they provide above and beyond? I mean is it worth the $500?
Well if you read what I said I am basically against spending 10 times what I can buy from Parts Express and according to my B&K 885 meter measure the same or better. Never commented on other crossover guys, just overpriced components.
Is this your opinion of his comment?
I have found the Parts Express DATS hardware/software to be extremely accurate when it comes to measuring resistance, inductance and capacitance. It's only $130USD.
Just an FYI.
Yes, I have version 2 and 3. The latest has a built in calibration resistor.
Of that $500, about $300~$350 is parts, the rest is labor. The ALK Universal is a good crossover for it's intended purpose. But there is so much documentation available, it is easy to build your own.
I prefer the ALK Universal for Klipsch Heritage speakers. It rolls the midrange off on the upper end faster and provides 18dB on the tweeter. It also allows you to attenuate the mid range easily.
Just an FYI.
Pretty awesome stuff. Wish they had come out with this years ago before I bought my meter. To be honest I never learned to use DATS for this since I had the meter anyway. Crites used one of these B&K's so I got one two.
I guess I ought to unbox and use my DATS some day.
