Speaker looks impossible to take apart the cable got cut in the middle was not successful in re connecting it to another aux cable wich was ruined I guess .More descrption. Is it a 3.5mm plug, proprietary plug? Can you obtain access inside the plug areas; male & female. Pics are worth a post.
Any videos on soldering? I gotta wait til I get the tool to do it tho . Ahh so that’s why you can just connect the wires like you would a normal speaker.How are you soldering skills? That can be soldered back together. 3 VERY thin wires that probably have a 'covering' to protect the wires; they are enamel coated. Fiberglass brush takes the protection off the wires so you can solder them. Super small shrink tube for each wire. A couple of slightly larger shrink tube to protect those wires. Back in business. IF you can't solder, then find someone that can.
thanksHow are you soldering skills? That can be soldered back together. 3 VERY thin wires that probably have a 'covering' to protect the wires; they are enamel coated. Fiberglass brush takes the protection off the wires so you can solder them. Super small shrink tube for each wire. A couple of slightly larger shrink tube to protect those wires. Back in business. IF you can't solder, then find someone that can.
So It’s cheaper on amazon cool !you need a simple soldering iron, something like this or some you can get locally: (no affiliation)
https://www.amazon.com/GLE2016-Sold...coding=UTF8&psc=1&refRID=KV528K2R5SGMZG5Y6A2K
Or, ask a friend with a soldering iron.
You need to peel off like 1" of the wire, so you can hold the tiny conductors stretched in some way, and scrapping with the hot soldering iron + solder, it will burn the insulation and melt the solder into the wire. Once done this, you can solder the wires.
I can tell from those picts, it's a probe to test circuits, but I don't know where it's plugged to.View attachment 1510583 View attachment 1510584 View attachment 1510585
What in world is this thing for ? It useful for anything In Home audio ?
Looks like that thing from matrix 1.
Yeah it looks as if it is supposed to be hooked to a battery or some sort to power it. No plug in it must be a cheap model .I can tell from those picts, it's a probe to test circuits, but I don't know where it's plugged to.
What on earth is it for car audio ? Or electrical repair ?It looks to be 12v automotive trouble shooting probe, with bulb inside the handle used to trace automobile electrical power circuits.
The sharp end helps to pierce the insulation of the wires being probed, with minimal damage to the wires insulation being probed.
Can`t envision any home audio use, or benefit.
Would you suggest practice soldering on anything or just watch videos on it ?I'm 100% sure youtube has vids, but I can't point to a specific one.
