What I find odd is why would only 2 caps be glued. Glue is typically clear or tan. But look at the bumps of crud around the one picture. Seems odd to glue these down since 1 is 6.3V and the other is 35V.
sure looks like glue as others have noted. The physical size of the part not the value is usually what determines if the OEM manufacturer decided to glue the part in place or not.
At some point you may want to unsolder that cap and remove the glue. Over time many of these glues or manufacturing aids became conductive over time.
Looks like glue to me because the area covered by the caps' bodies is clean, and if the cap oozed goo, that area would certainly show some, since leakage is likely to occur around the caps' leads first. Also, cap leakage is likely to be sticky, whereas the glue will be dried hard.
