MWalt
I think you can raise the platter at least 1/8" without raising the capstan. The amount of "freeboard" on the platter's rim below the belt is the limiting factor.
Do you think it would be best to simply raise the bearing via spacers?
Mark
WOW very nice work, beautiful ! hey dont forget your teflon tape to seal the bearing cap. I used synthetic oil for the lubricant. Im polishing my Empire table bearing/platter right now. I noticed on the PL-41 without the belt if i give the platter a light push it will spin for quite a while !! I love the 41.
Man I have to get busy, your platter looks stellar ! Alotta hard work there, well maybe in an hour or two mine will look as good !!
bob
Thanks, Bob. I went ahead and assembled it back together this afternoon. Used the thrust washer that I got from Finnbow as well as the Teflon tape and Mobil 1 synthetic. I also polished the capstan while I was at it. My platter does the same as yours; smooth and once in motion tends to stay that way for quite a while. Now, just waiting for the new arm!
