Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
I have an AKAI GXC 570D cassette player which still sounds great but I think that the limiter is not working as well as it used to...does anyone know whether those limiters ever need to be serviced.
Generally, those are just a simple circuit that detects a voltage and then lowers the signal a bit as a result. There's no mechanical process involved.
well, the VU meter goes way into the red zone even when I use the limiter, previously when I would use it the VU meter needles moved just a little bit indicating that the limiter was working. I assume that it is not mechanical but electrical. There must be some way of checking the electronics of it to see which part is not working the way it used to. Thanks
David
That is a good idea, I have considered it but since I don't know anything about electronics, i just forgot it...I do have deoxit, I will try that. Thanks
