The ice shield i use is only 1/4 inch thick but the rubber is dense like lead so it deadens the noise, i tested it on plastic to make sure it would not damage the plastic on the horn, it has no solvent therefore no problem, it did not reduce the area inside the speaker cab by very much, i realize we need all of the area we can get, i left the upper part of the cab alone other than stick it on parts of the horn to reduce vibration. I cut the pieces precisely so that there was no overlap in the lower cab area, you may be correct about the area behind the horn but i felt this space we just added and is small, the idea was to deaden the cabinet and just doing the areas i mentioned achieved that.After installing the ice shield i replaced the fiberglass. Any Home Depot or roofing supply has these materials in their roofing section, i recommend you look for a roofer working in your area and after measuring what you need try and purchase some, you so not need an entire roll ,in my case i deal with all trades and it was easy for me to secure. One more note if you use tack down roll roofing you will not need to heat it just remove the plastic and stick it on, if you use ice shield it is only a little tacky so install it all then heat with a blow dryer to activate it. Still anxious to hear vl,s finding on the caps and such
