AndrewD4492
yep sure:Can you share what transistor substitutes you used first
Q721 originally 2sa914 ---> 2sa1220A
Q723 originally 2sc1953 ---> 2sc2690A
Q725originally 2sc1913 ---> 2sc2344. Also tried 2sc3298A with same result
Q727 originally 2sa913 ---> 2sa 1011. Also tried 2sa1306A with same result
both channels affected. However left channel (Q's quoted) is worse - only get to 10.30 on the volume before static distortion, whereas right channel gets to nearly 1.00pm before it distorts.
All components seem to have integrity and match side to side.
I did replace the MV1's with IN4004's yesterday. Three of the MV1's tested with forward resistance of 58kohm, the other with 465k ohm.(was on left channel. Matched the IN4004's for forward resistance at 56k ohm. Has made NO difference, although offset voltage is now +/- 1mV.
Any ideas on other substitutes that are available would be appreciated. I realise that the ones I subbed are obsolete, but I obtained them from WES in Australia, which is a reputable electronic warehouse that still has them, but nevertheless they may be dodgy.
Any suggestions welcome
