On the power supply board there are several pins which connect the board to the circuit, J801-815. Check the wires and make sure none of them are loose. Perhaps you have a bad connection.
Perhaps you have a bad wire or one of you wire wraps have failed. I have had wires detach at the wire wrap from manipulating the board to gain access to the trace side.
