This might be a little hard to read but I traced the path back from the PreOut L/R RCA jacks through the Low Filter and High Filter switches on the P600 Switch board, back to the P400, Tone Amp Board.
Can you access the P400 board connectors J405 and J406?
If you can then do this:
- Power OFF and unplugged
- Low Filter switch OFF
- High Filter switch OFF
- DMM set to measure Ohms
- Put one DMM lead on the PreOut RCA center conductor for the R channel (it might help to plug in an RCA cable to the PreOut jack then clip the DMM lead to the center conductor of the cable).
- Next, take the other DMM lead and attach it to the P400 board connector J405.
- You should get close to 0 Ohms, continuity.
- Next, do the same for the L channel.
- One DMM lead to center pin of the PreOut RCA L channel, the other lead to P400 board J406.
- You should get close to 0 Ohms continuity.
This test will verify wire continuity from the output of the Tone Amp board, filter switches, to the PreAmp outputs.
Let me know what you find out.
View attachment 3840446View attachment 3840447
The P400 board is under the bottom cover.
