Thank you!I think you have an earlier run since the production number looks to be purely sequential. Later models added numerical sequences to include production dates, runs, intended markets and even voltage sources.
I see you have the Pioneer SA-9500ii. I had that amp for about a year or so. How do you like it?
Is this wiring diagram in SM of 250M is correct? Can anyone confirm it? If someone has 250M is it possible to just take the top cover off and take a pic?
It will be then very helpful.
Thank you!
Yes, I will do all those during the restoration that I will start pretty soon. Currently, it is working when plugged into 100V step-down transformer.I believe the manual is correct, I can check with my 250 that's here though.
I would advise pulling the driver, predriver and output Transistors to verify that the gain is within the range that Marantz specifies, I've seen em drift pretty far out making it only a matter of time until the unit explodes.
The Transformer of the 250/250M is the same, so the wiring will be ok.
Thank you!Unlike the US/European models, those 250M Japanese versions are factory modified, attached some pics of the power board. When I got the first one, I thought some tech had modified only to realize these are factory mods, when I received 2 more of the same, all from serials 30,000+ and above. I restored the first 2 back to the original design, as I could not find any information on these mods. These power boards also have a standard BJT 2SA1124 in place of the PNP Darlington at location Q503. I did a full restore on the first 2, Pics of the first unit.
View attachment 2424590 View attachment 2424591View attachment 2424593View attachment 2424595 View attachment 2424596
Nice! How are the Audyns working for you?Thank you!
I have completed the project this summer with a full recap and all of the service bulletin works were already factory done. I completed the voltage conversion and a full recap of the main amp and power supply board.
View attachment 2424792 View attachment 2424793
I like it a lot! I also used these in my Accuphase P-300, love the results!Nice! How are the Audyns working for you?
A lot more than just the service bulletins are done on these Japanese versions, no available documentation though.Thank you!
I don't know about all of them but if there is a red sticker on the rear of the top cover saying converted to 100V then it is.Do the Japanese serial number models have the same transformer that is multi voltage for 220 and 240v also?
Yes they are multi-voltage transformer, however I noticed a difference on the DC output,Do the Japanese serial number models have the same transformer that is multi voltage for 220 and 240v also?
Thanks for the clarity I have a 240v version with those same mods which look factory initially I thought was a old repair but seeing those boards makes me think it was factory delivered that wayYes they are multi-voltage transformer, however I noticed a difference on the DC output,
I am assuming the lower rail voltage is making the unit clip at the rated wattage of 125 watts or possible all those mods have something to do with it. I am going to restore the 3 unit and keep those Japanese mods on it and then compare the two. Keen to know of any changes to the sound character with q503 as PNP Darlington and as a general BJT like the 250 model.
- On these Japanese version the dc rail voltage is 56.5 volts with the variac voltage set to perfect 240Volts,while the US/European models I have the DC rail voltage is 58.5 Volts. Point to note My 1200B runs at 53.5 volts.
- The current limited variable resistors missing on these Japanese boards and these unit clipped at 125.5 watts in 8ohms load (when unrestored and with the Japanese mods in place).
- On the US/European Models I have, I was able to drive the to 139/142 watts before clipping, of course the adjustment had to be made as per the service manual to clip at 125 watts for protection, which I did after testing.
