Yes, I would love a parts list... Does it include transistors...?
Ok, So I replaced all of the yellow Philips caps and everything was working great and then I decided to replace transistors and I think I've made things worse...
Here's where I am: I replaced all of the transistors (the pre-driver, drivers and outputs are already replaced. Once i hooked it back up, the bias voltage continues to climb up to about 20mV with the bias pot turned all of the way down. Tried putting back the ones the were way different hFE but still unstable. Wound up putting all of the original transistors back and now it's working.
So, I'm running with the original transistors until I have a problem... I did leave in the new differential pair because I didn't feel like reworking them...
The list below are replacements that I made... Could not get the bias voltage to stabilize with the new parts. always climbing to the 30+ mV range for some reason.
Can anyone explain why these didn't work... The darlington (Q503) has the largest gain difference. When I put the original back, no difference in stability. The rest were pretty close in hFE.
| Ref | Type | Original Part | Replacement Part | Original hFE | Replacement hFE | Datasheet hFE |
| Q501 | NPN | 2N5961 | 2N5961 | 263 | 300 | 150-1000 |
| Q502 | NPN | 2N5961 | 2N5961 | 309 | 300 | 150-1000 |
| Q503 | PNP Darlington | MPSA65 | MPSA65 | 20200 | 76200 | 20K - 50K |
| Q504 | NPN | SPS1951 | BC547B | 232 | 277 | 110-800 |
| Q505 | PNP | 2N4125 | 2N3906 | 124 | 173 | 100-300 |
| Q506 | NPN | 2N4123 | 2N3904 | 94.7 | 225 | 100-300 |
| Q516 | NPN | MPSA43 | MPSA43 | 83.6 | 54.1 | 50-200 |
| Q517 | PNP | MPSA93 | MPSA93 | 60 | 105 | 40 |
| Q518 | PNP | MPS6519 | MPS6519 | 252 | 391 | 150-500 |
| Q519 | NPN | SPS1928 | BC550C | 595 | 603 | 100-800 |
| Q520 | NPN | 2N4123 | 2N3904 | 85.8 | 223 | 100-300 |
| Q521 | PNP | MPS6519 | MPS6519 | 133 | 389 | 150-500 |
Cheers and Thanks,
Wade
