I have been listening to the MLTL-10 speakers with the revised crossovers - and I could not be happier with their sound. Basically, the speakers have no sound of their own - each and every recording I play, sounds its best! The flaws in some recordings are revealed, and the life and spirit of many recordings, is just as evident.
The amp that gets them singing like this, is the B&K ST-140. I have recently replaced all the capacitors in the amp, and it makes this purity of sound just happen. My other amp, the Schiit Vidar is competent enough, but it sounds small and a bit two dimensional, and doesn't let the system "come to life" like the ST-140 does.
Someone on the DIY Audio forum made a very good suggestion - to redesign the bottom on the cabinet, to locate the terminus opening on the back. Their reason for this being better, was that any higher frequencies that exit that way would be less audible. And they're right - the Hornresp model shows more of this, than it is in reality, because the model is straight, and the speaker is "folded". Also, I have added eggcrate foam in the speaker, and Hornresp is not able to model foam.
But there is another reason to have the opening at the back - it is 18" / 45.7cm closer to the back wall, and the lowest frequencies that are coming mainly from the opening - below ~30Hz - will have greater room lift. Which makes this speaker truly full spectrum.
Here's the revised drawing - see attached image.
The F3 point predicted in Hornresp is awesomely low at 26.4Hz; and this is with less poly-fil than in the current version. I am also attaching the Hornresp screen capture.
The ripples at ~200Hz and up will largely be eliminated by the folded transmission line, and by eggcrate foam that I will installed in the bottom of the 3rd segment. The slight slope down below ~180Hz will probably help limit the room modes that I have in my room, and are usually present in most rooms. These speakers have more bass - and much better quality bass - than any speaker I have ever heard. And having significant bass all the way to 20Hz ( and slightly below!) in room - is so wonderful, I cannot find the words ...
A couple of other points that this revision improves on: the bottom of the closed end is angled at 45 degrees - the average distance (at the centerline) is the same as before, so the tuning of the chamber is fundamentally the same. BUT, it will have less standing waves, and will have a broader range of resonant frequencies.
In addition to the angle at the top back, I added an angle at the bottom - this is not for "turning" the air around the corner (this happens virtually the same without the angle, in this section very the air is moving back and forth) - but to break up standing waves.
