MC2205 Lamp Board - Project for 2020 ?
Hofvox
Where can I find a MC2205 lamp board? McIntosh is out and Audio Classics out.
What Happened:
On the many units I have worked on, the traces have lifted or solder tabs completely broken off in the area of the Bi-Pin lamps. It appears the weekend hobbyist trying to convert the LEDs are not careful when inserting those Bi-Pin lamps forcing the traces to bend upwards or fracturing. I have a new and improved concept lamp board designed as a replacement.
Making boards nowadays is a simple and an inexpensive process even in small quantities. I would like to make a dozen or so boards for my use. Other than modifying the traces to meet McIntosh approval I will add a "solder to board screw down header" for the 6 original wires. Instead of soldering original 6 wires onto the new board you just screw them onto the new header. The original board is a very simple design and simply attaches via 2 standard lock washer nuts making ground. The 10 pin spiked header will remain on the new board like the original.
Bottom Line: I would rather send a dead or trashed board and not one currently in any of my units. Thus, looking for a trashed or extra board without having to buy a completely trashed unit to harvest donor board.
