I am waiting for new speakers to arrive (Focal Kanta No. 2)....how do I start over with the MEN220 so I can start fresh with a new profile? Do I need to factory reset?
When you are set up to take measurements Room Perfect in focus position it ask you if you want to add or write over existing data files. If you choose yes it will save over from the start as new focus position 1. Then you take other room positions from there 2 through 9 or 12 until you get desired room knowledge.
The MEN is for room correction, the tone controls on your pre-amp are for program source correction/taste.
Do not get the two confused.
First you must start with at nominal point with your system, a "blank canvas" if you will. Then when you play your music, you can tickle it to suit.
