Minimus 7W replacement tweeter
LoGiCa
Hi, I just got hold of a nice condition pair of Minimus 7W.
Unfortunately one of the tweeters is dead.Does anyone know if there is a suitable replacement for these?
I assume it would be best to replace both tweeters?
Make sure you get the right tweeter. Check the number on the back of the cabinet. 40-2030a and b take the same tweeter but 40-2030c is different. There is a used one on ebay for the 40-2030a and b right now for 20 bucks.
Hi, thanks for the reply.
The number on the back of my speakers is 40-2039b
Tweeter is SD-59 8ohms. Would the SD-13 I have seen on eBay be the same?
You know for sure that it's a bad tweeter and not a loose wire, or a problem with the crossover?
Min 7s are so common, you can probably get a direct replacement with just a little patience. They show up on ebay often, and I know for a fact that there are some singles on AK's BarterTown.
They rarely come up for sale in the U.K.
I can't see any posts in Barter Town section. How do I use that area of the site?
I can't see any posts in BarterTown section. How do I use that area of the site?
Kind of an important detail,your location?
I have bought several pairs of Min 7 for $20.00 or less so a tweeter for that......
You need to be a paid subscriber here to see Bartertown.
I didn't know at first either.
Welcome
Ed
I can't find a single replacement SD-59 but there is a pair of SD-60 tweeters (8 ohms) would they be a suitable replacement?
Probably :scratch2: If the faceplate is the same size you should be OK. Even if that faceplate is a different size, you can remove the driver and mount it in your faceplate. They're only mounted to the faceplate with three screws.
