DenisMSK1987
She did not go down from the boss. So he climbed under the upper part of the arm (but I can’t take it apart anyway)
I found out why that screw had likely gone missing. The height adjustment is based on a spring loaded shaft that is stopped in position by the screw head. In this case, the shaft was firmly seized in place, so screw adjustment did nothing. I had the entire TA apart to change the bulbs and (clean out the goo) belt. Took some Kroil and judicious working of the shaft with the spring removed and was finally able to work it loose. Light sanding and fresh grease, and it now is smooth in operation, and the shortened screw with the right sized SS washer allows easy height adjustment. The only really odd thig on this LT-30 is even with the cam for the start location at maximum, the stylus barely reaches the right location, and even then, I have to set the CUE stop location a bit too far in so that the TA starts with it canted towards the record (which then of course, straightens out). Then at EOR, it reaches all the way to the label before retuning normally. Like the slots are not the right length, (since EOR is dependent on Start of record) Hmm, it just occurred to me, I wonder (since I replaced all the bulbs) if they might be a scosh too dull to trigger as soon as a brighter bulb. That would explain everything. Easy to test, I had used extra long life 14V 65mA bulbs. I have some 7219 12V 60mA as well, that would be brighter.
The large metal drum (topmost in the first pic) should have 2 turns of cable. The plastic pulley on the right (second pic) is spring-loaded to maintain tension on the cable. You can just make out the pivot of the arm to which the pulley is attached. The cable needs to loop around the drum from the top to the bottom from left to right.
