Mixing Advent speakers
Hello
Does anyone know if it is ok/safe to use an Advent/3 & an Advent/4 as pair together, I have one of each.
Thanks for any info!
It really depends on the amp or receiver. What brand and model are you using?
I believe most Advents are rated at 8 ohms impedance, so that means that running two pairs together should present a 4 ohm load. Some amps don't like that low of a load.
Hold on, I just read that you have one of each, my bad!
I wouldn't play them together because the /4s are more efficient and have a larger woofer, so they will sound different.
You could use them together if that's all you have, but there will be differences. The text below describing the two speakers was taken from the Identifying Your Advents sticky in the speaker forum. Even though the 3 and 4 use different sized woofers, the biggest difference is the efficiency ratings. The /4 will be noticeably louder than the Advent 3.
The advent /3 is a great small bookshelf that still has the classic look and sound. It uses the same cone tweeter as the model 2, but only one instead of two in an array. The plus to the /3 was the amazing bass response for such a small box. However, its downfall is its terrible efficiency (85db / watt) which makes it power hungry, but at the same time easy to bottom out if you turn them up. Most will use them in an environment where good sound is preferred but excessive volume is not (IE an office or bedroom)
The woofers were 6" with butyl surrounds or treated cloth surrounds (depending on year produced)
The advent /4 was the solution to replace the old Advent /3 --which although was a good speaker -was inefficient. The woofer and tweeter were used in later designs. There were also two grill designs like the /1 -one rounded grill and one sharp. It's an 8" two-way design.
But what if I for instance put two speakers on channel a and then put two speakers and a subwoofer on channel b? Could you safely run those together at the same time?
Assuming it's a powered subwoofer, it doesn't place any significant load on the amplifier so it shouldn't be a problem.
I assume you mean that there are 2 speakers connected to the A speaker jacks and 2 to the B speaker jacks? If the sub is powered, you can connect it to the speaker jacks and then connect the B or A speakers to the outs on the sub.
You could do this if both pairs are 8 ohms. You will then be driving a 4 ohm load. The sub has it's own amp so it will not be affected by the impedance of the speakers.
The subwoofer I have is a Klipsch KG passive.
