Hopefully this won't offend, but when I read Dave's post about claiming his 9300 work up was hardly an effort to make it a Picasso I was instantly confused. My experience with Picasso brought images far from the simplistic beauty of a 9300.
My experience with amps is very basic. I haven't ever even seen or heard, much less owned or worked on many of the works of art I've read about here and elsewhere. But I generally wouldn't compare them with Picasso. Seems his lack of realism and distortion of perspective are contrary to the transparent clarity sought for in an amp.
As a fun sidebar, I will say that as far as 9300 power supplies go, I think my Maggie Console Power Supply is a bit of a Picasso.
Again, hope this didn't offend. Picasso is great.
Just gotta wonder what was going on in his head sometimes.
This is where a scope wirh a signal generator on a dummy load is useful. After ensuring symmetrical drive, match the output tubes for symmetrical clipping.
I'm using my ST 1700A for this. Its a signal generator, THD meter, and has internal watt and voltmeter functions. It also happens to have a scale on there for wattage across an external 8 ohm load. Its not a wattmeter per se, its just a scale on a voltmeter that takes having to do the math out of the equation. Seems there is a bit of disagreement from the 10v/10w scale to the 30v/100w scale. Its 40 odd years old now, quite probably the divider network resistors are not dead-on anymore.
Its running pentode mode at the moment. Gave me less than 1w extra. I've got the EFB setup in there as well. Wouldn't that work effectively like fixed bias, or should I look into building a proper negative bias supply for this and grounding the cathodes? I'd think that the primary impedance is close enough to the stock 7628 to let this mostly work. I guess it might be worth confirming they are indeed an 8k primary, and that the screen and plate taps aren't reversed. I have it wired up properly per the schematic that came with them, but if they got the connections inside reversed that would certainly screw things up.
EFB IS fixed bias, as in the bias is not affected by current flow through the output tubes like cathode bias is, but neither is it blindly fixed like traditional fixed bias is. Rather, it automatically adjusts accordingly based on the screen B+ voltage.
Have you measured the primary impedance to confirm their 8K specification? The original transformers were about 7600 ohms, but that simply won't make that much difference if the Edcors are in fact 8K units. How are you powering the screens?
If you are only getting about 11 watts of power output -- particularly if that is only with one channel driven, then something is not as it would appear to be. With a 121 vac line, the buck connection in place, using a 5AR4 rectifier tube, EFB, and good output tubes, you should have no problem developing at least 15 watts with a single channel driven (the unit here would produce 17 watts in that scenario). Have you got an alternate meter of known calibration you can use for verification of the output voltage delivered into a known 8 ohm load?
Your math is better than mine! However, I use 10V in as I find it easier/more accurate to read higher V... But yeah, 40X sounds high....
