Well, better late than never!! Sorry I've not been following this thread along since it's inception, but been too busy with DG-SE1s, and then got into this little Sylvania console amp....which is the subject of a couple of threads I have going here on AK as well.
Just a couple of comments on prior posts, one as related to the use of 'new' 5AR4s vs some of the current production units. Dave, PLEASE jump in on this.....as in reading this thread I don't believe I saw a note anywhere on the total current drawn from the HV in the PS of this unit. But, my thoughts on 5AR4 rectifiers are that the new ones are fine in amps where you're not approaching the current limit stated for the tube...which if I recall, is about 240 or 250 ma. I don't think this amp is even over 200ma.....or perhaps even significantly lower....particularly with EFB, but I'm thinking that in most any amp with under 200ma of current draw, the 'new' units....even those Chinese units from Tube Amp Doctor or Ruby...they would work fine! However....just my opinion here...but in amps like the Dynaco ST-70, the MkII/III, or even some of the 'integrated' units like the Scott 299C/D or 233 series...those amps really deserve a 'vintage' rectifier just to assure that the current levels are as 'available' as possible. Not saying that the new Sovteks, JJ, or others 'won't' do the job....but I'd far rather have a nice Amperex, Mullard, Telefunkin, or even an old US version in a 'big' amp. Dave, maybe you could comment as to the total current draws w/ or w/o EFB in this amp?
Also, as to the EFB, this Sylvania amp I'm currently working on is very close in many ways to this Maggie. PI stage is pretty similar, but the AF stage is Pentode driven....and the amp uses a 6BL8 vs the 6EU7/12AX7. Also the Sylvania came with it's output section already 'split' into two cathode resistors....with NO bypass caps. So, there are some other issues at play in that amp as well....particularly as related to the power supply, screen voltages, and supply voltages at the plates of the driver tubes. BUT....one BIG advantage that I discovered is that the 7.6K primary impedance on the OTs is at 8 ohm....not 4. So, this amp is getting a good bit of attention from me...which brings me to the point: Dave, do you think I could pretty much 'copy' your EFB as you have it in this Maggie circuit and 'adopt' it into the Sylvania, providing I massage the other voltages to the OTs and 6BQ5s to reflect the same basic values as those in the Maggie?
Needless to say...... more 'incredible' work from the 'master'!! Like a few others, I too have one of these 9300s on the shelf....and just may have to take the jump with it as well. OH.....I wanted to ask if you think these basic changes would also apply to the 6V6 version?
Thanks Dave!! Tom D.
