THE PHASE INVERTER, FREQUENCY RESPONSE, STABILITY, AND OTHER STUFF.........
This part of the project starts -- once again -- with the output transformer, as it determines so much of the performance outcome of any feedback amplifier.
The original 9300 design operates with 12 db of NFB, which proved to be right at the maximum amount of NFB that the OPT can handle if HF stability is to be reasonably maintained. Greater amounts of FB produced poor stability with speaker loads, while any reduction in FB hurt distortion, frequency response, and increased output impedance. So 12 db proved to be the optimum level for the transformer, which is the amount that Magnavox used, and I continued to use throughout the project.
With this relatively small amount of feedback, the transformer's resonance characteristic causes a significant amount of ringing to appear on square waves that cannot be tamped down by the usual method: Ergo, there is no feedback cap across the feedback resistor in any of the 9300's offerings. In fact, the use of any such cap seriously compromises HF stability in this design. But left unchecked, the resonance characteristic that all OPTs have makes for a rising HF response characteristic right up to the transformer's resonant frequency under feedback conditions. Besides this undesirable outcome, the complex load that a speaker represents can then take this response pattern, alter its phase as a FB signal, and change it from a negative one to a positive one at supersonic frequencies. Helloooo instability!
In the best designs, the OPT's resonance is pushed to such a high frequency, that amplifier response can be controlled to remain well under that frequency, while the effects of that control still all occur safely above the upper portions of the audio band. This leaves response at the higher audio frequencies (up to 20 kHz) ruler flat, with all the other benefits of NFB in place throughout the audio bandwidth as well, and the amplifier relatively insensitive to speaker loading with regards to HF stability. Buuuuut, that's not what we're dealing with here. The resonance and phase shift characteristics of the 9300's transformers are such that both basic frequency response and power transfer capabilities are well compromised down into even the mid-range audio frequencies (above 1 kHz), so that any remedies for improvement must be well tempered, save the medicine becoming worse than the disease. So what to do?
Magnavox dealt with the rising response issue by limiting the HF response of the phase inverter stage -- the normal way such a goal would be approached. This was done by way of the 47K input grid resistor for the AF amplifier section of the 6EU7, the use of relatively high value plate load resistors for both sections of that tube, and (when installed) those little 100 pF caps that were connected to either the plate or grid elements of the AF amplifier stage. Together, these measures were meant to counter the rising response created by the use of 12 db of uncompensated NFB around the 9300's OPTs. But without any active HF corrective action around the entire amplifier that is a form of NFB itself, it leaves both the AF Amplifier/Phase Inverter section and the output stage section operating quite independently of each other, with therefore nothing to account (HF wise) for variances in tube characteristics, component tolerances, or slight differences in wiring layout. To that point, this is a significant part of what a traditional small cap across a NFB resistor accomplishes -- except that form of compensation can't be used here. Additionally, beside the measures already mentioned to control the response of the AF Amp/Phase Inverter section, one other measure of control was used as well: The inherent frequency imbalance that occurs between the outputs of a Paraphase type inverter circuit.
Within the hierarchy of phase inverter circuits, the paraphase inverter design -- as used in the 9300 -- is a bottom feeder: There is precious little within the design that acts to maintain an equal balance between the two outputs with regards to either frequency response, or component variations. As a result, while the balance can be made to be generally accurate at mid-band frequencies, as the frequency varies either way, the effects of Miller in the inverter section on the high end, or the additional (bottom) coupling cap on the low end really cause the imbalance to grow as frequency deviates above or below the mid-band range. Either way, the response in the bottom output leg becomes rolled off as compared to that from the top. Also, even with mid-band balance established, that can be upset with component or tube changes over time. As a phase inverter, it does work. But for high quality applications, it only works after a fashion, having little to hang its hat on. In any event, it is the inherent HF roll-off in the inverter section of this inverter that Magnavox was counting on to help control the rising response produced by the uncompensated feedback network.
With the deck stacked against this type of inverter then, and the lack of any active HF NFB compensation, it's no wonder then that HF transient performance was poor, HF stability was marginal, distortion due to frequency imbalance high, and overall frequency response anything but flat. The results of this design approach are all well depicted in the base line data, and in the square wave pics presented. But remember, this was designed for an economy console setting. There were no long speaker cables or complicated crossover networks to upset stability, speaker networks could be tailored to account for amplifier response, and tone controls were likely set at anything but flat in the system anyway. At the moderate output levels the unit was was designed to operate at, the sound produced was no doubt enjoyable, so it's doubtful that anybody was really concerned about the limitations of the design. These consoles were all about enjoyment of rich velvety sound rather than high fidelity accuracy. Today however, these amplifiers are now operating in stand alone settings, often driving high definition speakers of which each speaker new alone cost more than the whole console did in equivalent dollars back in the day, with long speaker cables and potentially high capacitance loads, amplifying recorded music with more dynamic range than its designers could ever dream of. Today, the spotlight on these amplifiers is focused and bright. It is that reality then that drives the effort to raise things up a tick.
To that end, along with the modifications to the power supply and output stages, the original phase inverter has now been modified as well, with more gain, a new NFB and HF stability arrangement, and greatly improved frequency balance, which all work together to produce lower distortion, improved stability, and a flat frequency response, and which are now well maintained regardless of tube characteristics and/or component tolerances. At this point then, all this has been accomplished by way of circuit design changes alone, while still maintaining the original building blocks of the 9300 amplifier: The chassis and it's transformers. Down the road, new OPTs will be considered, as that is now the only thing standing between current status, and a really high ranking performance wise. With the modifications developed, the amplifier is now worthy of whatever OPTs you might want to put into it. But that's down the road. For now, this is going to be a temporary soft landing point until other projects and family needs can be attended to. For the 9300 however, it's really a great place to land: costs for the modifications are low, they are easy to perform, and the return is high. With the table fully set then, I hope to have the schematics posted tonight, showing how all the issues of the 9300 have been dealt with.
Dave
