Jason Zhang
I found adjusting the idling current is quite difficult. It took long time to settle after adjustment. Maybe this is due to bad Q333/Q334?
My experience shows the quiescent current drift as typical, especially if you're cutting power to the amp before attaching meter leads to TP201/202. What I've observed is that upon power application the bias will start at around 5mV then drift upwards quickly for about 30-45 seconds then slow. The NAD 2200/2600/2700 amps use NPN-PNP transistors in a "Sziklai" pair: https://en.wikipedia.org/wiki/Complementary_feedback_pair The article suggests ~10mV as a reasonable bias level, but at what latency? I've been using a stopwatch as a standard and setting the POTs for 10mV after 2 minutes on an idle (and properly warmed up) amp. if I measure after that the bias will continue to creep up but remember when in use it likely won't because the current will be used to drive the speakers.I found adjusting the idling current is quite difficult. It took long time to settle after adjustment. Maybe this is due to bad Q333/Q334?
IMHO, with respect to audio subjectivity is huge. And so is your system, what you hear is VERY dependent on speakers, source material/devices, and interconnects. Depending on your experience level, I'd advise finding ways to hear what distortion sounds like at various volume levels and frequencies without risking your "good" equipment. These NAD amps are AMAZING when in a properly configured "system" but can also sound like crap (and destroy things) when not. Google can be your friend, but so can a good dealer/technician who is willing to take a moment to measure and hopefully confirm your observations.Thanks for your explanation guys. I don't have scope to check if it is distorting. I tried to play 1khz tone which sounds clean to me.
I'm guessing your Logans are from the ElectroMotion line? Not that it'd wrong to drive something from the Masterpiece series with a ~$250 amp, a 2200 can certainly deal with low impedance loads. Either way, I've always dreamed of owning something electrostatic but the closest I've gotten is a pair of HiFiMan HE400 planar magnetice headphones!My speakers are on the more resolving side. They are Martin Logan electrostats.
Mines are ML Vistas. It does have a bigger panel than the current ESL lines. But this amp is more than powerful enough to drive these speakers I feel. At about 1A, the volume is pretty much the loudest that I can bear. Before this I’m using Marantz sr6010 to drive these speakers, which ended up with not enough bass. This amp definitely has improved the low end a lot. I’ve also over killed it when I did the recap of this amp. I pretty much replaced all the ceramics with polystyrene, which I swear that I can hear the difference in terms of details. And later I changed the coupling capacitors to solen fast caps. This further improved the details and added a tiny bit of warmness to the sound. So overall, this project ended up well I think.I'm guessing your Logans are from the ElectroMotion line? Not that it'd wrong to drive something from the Masterpiece series with a ~$250 amp, a 2200 can certainly deal with low impedance loads. Either way, I've always dreamed of owning something electrostatic but the closest I've gotten is a pair of HiFiMan HE400 planar magnetice headphones!![]()
That's normal, output transistors (and probably most passive electronic components) have an optimum operating temperature. I linked this article on bias adjustment earlier in the thread: https://www.tnt-audio.com/clinica/bias_e.html The manufacturer's recommended spec is made for a number or reasons and is always likely to be conservative. As long as the unit isn't WAY out of spec it'll be fine.Today I found something even more interesting. Somehow whether I put on the top cover or not has an effect on the idling current. With the cover on. TP201/202 slowly increased to about 12mv. When I took it off. It dropped back to 7.5mv slowly.
Hey how'd it go? I had a question on this. This is a nice tip! Looks like they still have 30 in-stock. Did you mean C413/414? I might not have done anything with these and C411/412. The big ones. Did you?For anyone that doesn't want to mess with the dummy pins on the United Chemicon 100v caps Newark has these Kemets: https://www.newark.com/kemet/alc70a103eh100/aluminium-electrolytic-capacitor/dp/85AC3988 The snap-in pins JUST fit into the wide pads on the PCB!
I've installed the Kemets at C411/412 on a pair of 2200s so far and they seem to work quite well, good enough that I have one more pair to use in my 2600 too. Pwauk12's posts earlier in the thread nicely cover the application. The high voltage rails on the 2200/2600 run around 90v so a cap with a 100v rating (and higher surge spec) is compatible. Dimensionally they're smaller than the OE Nichicons so I've been using a thin layer of black RTV sealant on the bottoms to hold them to the PCB a little better as the snap pins take much less solder than the OE blade style terminals.Hey how'd it go? I had a question on this. This is a nice tip! Looks like they still have 30 in-stock.
Not sure how a BJT amp like a 2200 will cure your itch but as long as you're pleased that's all that matters!will help cure a confounded itch i've got right now to get a MOSFET power amplifier.
Keep in mind that the 100v United Chemicons have a pair of dummy terminals so you'd have to drill holes in the PCB to accommodate that. According to their spec sheet that series is available without the extra terminals but I didn't find a convenient vendor that sold them.So now I've a draft plan to go with the United Chemi-Cons on the high and the KS series on the low. Have used the KS before.
Yeah, I did the same thing...installed DIP sockets. I bought LME49720NAs for both 2200s and a pair of OPA2134 ICs to try as well but haven't gotten around to swapping those in yet.I've the socket in there (with LM4562 installed). Why not have some fun.
I saw that and was thinking about it today. My original thought was planning on drilling the PCB or snipping the dummy leads depending on what I saw. What I was thinking and having second thoughts about though, today, was -- I could not really tell the Chemicon's specs from the datasheet. I was wondering if perhaps additionally the Kemet might offer superior properties. Someone was telling me today if I was hankering to update the filter caps in my Yamaha A-1020 integrated he would recommend with going with one of the Kemets.Keep in mind that the 100v United Chemicons have a pair of dummy terminals so you'd have to drill holes in the PCB to accommodate that. According to their spec sheet that series is available without the extra terminals but I didn't find a convenient vendor that sold them.
