Yes, it is the local decoupling capacitor for the B+ rail.Does C426 decouple the supply to earth?
What are the board designations for these capacitors? Are they in the RIAA feedback loop?Mylar capacitor replacement.
I want to replace two pairs of these green ones with polypropylene caps for the phono path but need to know what values to order. The marking on the sides are:
00752J 50VF
.027J 50VF
Does anyone know what values these are and what I should be specifying for the order, ideally from
https://uk.farnell.com/
What are the resistors in parallel with these capacitors? In the 3020B phono schematic, there are also C427/C428 in parallel with C413/414, is that the case with your 3020A?Thanks guys.
They’re pair C413+C414, and C415+C416.
Leestereo, you recommended these locations as I’m trying to optimise the phono section.
